00-01 rear window replacement
Old Nov 23, 2005 | 06:24 PM
wil687's Avatar
I appreciate the info and pics, I need to do the same to my 00
Old Nov 25, 2005 | 10:34 AM
steven975's Avatar
i don't think you need to crack open the roll hoops or take out the bottom trim. I think there is a way to get the rain rail loose without going through all of that.
also, the roll hoops don't go back together right when you crack them open.
Old Nov 25, 2005 | 11:13 PM
ItsBen's Avatar
Just cracked my window last night. Going to try to ask for a goodwill warrenty from the local dealership. If that won't work then I'll have to try this. How much is the plastic window piece?
Old Nov 26, 2005 | 01:32 AM
Squeezer's Avatar
http://www.hondaautomotiveparts.com/auto/j...=SOFT+TOP+CLOTH
243.43
Old Nov 26, 2005 | 06:33 AM
Cyclon36's Avatar
Nice Thanks for posting up the pics. I'm adding this to my How-to list in my signature.
BTW, The plastic pin that you're removing in the fourth picture with the screwdriver can be removed by pressing the center section in. That loosens the inside part and lets you pull it out easily. I can't tell if you did that and are just pulling it out with the screwdriver the rest of the way or if you're trying to pry it out with the screwdriver to begin with.
Old Nov 26, 2005 | 06:48 AM
Slows2k's Avatar
The roll hoops are not designed to have the plastic taken apart. They are meant to be unbolted from the body of the car. Seperating the plastic will require you to glue them back together. Many have tried to glue them unsuccesfully.
Old Dec 12, 2005 | 06:19 PM
jeffxyan's Avatar
Me being one of them. Don't do it. Don't seperate the roll hoops. They won't go back together. I have zip ties holding mine together.
Old Dec 13, 2005 | 08:59 PM
inner's Avatar
I did press the center section in, and I'm just pulling it out with a screwdriver
Old Dec 13, 2005 | 09:05 PM
inner's Avatar
I know that they are not supposed to be taken apart but the guys at the shop where I had my seatbelts replaced just ripped it apart (said that this was the first S they'd worked on) But because they were already apart when I decided to replace the window, I did not have to remove the glovebox.
Old Sep 24, 2006 | 12:03 AM
TookayS2K's Avatar
any1 still have these pictures?
i would love to see them.
