Video - Dyno Runs - SC & 2ndary Fuel Inject. Sys.
For those that have never had a chance to Dyno their car, here's a little taste of the experience.
Many thanks to those who helped make this video of my last dyno possible. It was just pure dumb luck that I was in the right place at the right time when Kevin was filming baseline dyno runs of his brother's new Z. He was kind enough to put this together for me.
The combined effect of the Comptech SC w/ AC and Ballistic's Secondary Fuel Injection System yielded an incremental 90 whp per dyno. Next comes the Comptech 7 lbs. pulley and gauges.
Videographer = Kevin Lee of 3:ayemstudios, absolutely amazing job working late into the evening!!
Installer Extrordinaire & maker of the Secondary Fuel Injection System = Scott aka "Twiztid" @ Ballistic Motors in Manchester, NH
Dyno = HolyRoller Dyno (Giles aka "Gilbertg")
Web Hosting = Erick aka "Elmmx5"
Let me know what you think of the video.
HolyRoller Dyno Run
HolyRoller Dyno Run
Originally Posted by Asura,Jan 31 2006, 10:00 PM
So you got 90 whp from a Comptech SC/AC + secondary injectors.
How much of that 90 whp do you attribute to the secondary injectors?
Dyno Results From Initial Owner
I've seen the set-up, but the S2000 with 6 psi is not fuel starved. I thought the main reason for that was better fuel economy off boost.
I'd do it for that alone if there was a kit available, but as for making hp, I am skeptical.
Originally Posted by trivium,Jan 31 2006, 11:00 PM
That seems to be pretty low for your setup. I guess the secondary injector system is not so special..
I believe it is planned to be available later this year.
I've seen the raw rail stock at Ballistic. They are working out the details on availability of key pieces and some asthetic design changes.
For now, its one of a kind.
