installing godzilla bov
Old Feb 11, 2006 | 09:36 PM
D-S2K's Avatar
Default installing godzilla bov
it seems like a fairly easy job so i'm going to do it myself. but does anyone know if there's a write up for the godzilla bov installation instructions? if so, please post it, just to make sure i dont mess anything up.
2nd, what do you do for the inlet on the supercharger side? i know that i can't leave it open, so what should i do or use to "cork" the opening on the supercharger side?
Old Feb 12, 2006 | 02:25 PM
AusS2000's Avatar
Screw it on, plug the hole.
Old Feb 12, 2006 | 05:05 PM
SIIK2NR's Avatar
I used rubber end caps that I found at Home Depot. They fit inside the hole but do not pass through.
Here are the pictures of it on the car..
Old Feb 12, 2006 | 07:37 PM
D-S2K's Avatar
sweet. thanks for the pics and captions.
one more thing, what size are those end caps that you found from home depot?
Old Feb 12, 2006 | 07:40 PM
AusS2000's Avatar
The inner diameter of the hole is 1" (25mm).
Old Feb 12, 2006 | 07:41 PM
AusS2000's Avatar
Just saw your vacuum plumbing. I was advised to run a lead directly from the manifold to the Godzilla for the strongest vacuum. How well does it work in your set up?
Old Feb 13, 2006 | 04:45 PM
r_duff's Avatar
as far as corking the comptech bypass, you can just remove the vacuum line to it. it will stay shut.
Old Feb 13, 2006 | 04:58 PM
SIIK2NR's Avatar
This is true.... most people just remove it for the cosmetics.
As for the Vaccum line to the BOV... it is essentially a direct line. The BOV comes with the "Y" gate for the line to the ACV valve.
prince buster
May 4, 2016 12:58 PM
MugenAP2
South Florida
Sep 14, 2010 05:50 AM
Vixen
Jul 17, 2008 03:24 PM
Moreno5
Aug 8, 2006 09:36 AM
paivag
Jan 18, 2006 01:36 PM
