installing godzilla bov
it seems like a fairly easy job so i'm going to do it myself. but does anyone know if there's a write up for the godzilla bov installation instructions? if so, please post it, just to make sure i dont mess anything up.
2nd, what do you do for the inlet on the supercharger side? i know that i can't leave it open, so what should i do or use to "cork" the opening on the supercharger side?
Originally Posted by SIIK2NR,Feb 12 2006, 06:05 PM
I used rubber end caps that I found at Home Depot. They fit inside the hole but do not pass through.
one more thing, what size are those end caps that you found from home depot?
Originally Posted by r_duff,Feb 13 2006, 05:45 PM
as far as corking the comptech bypass, you can just remove the vacuum line to it. it will stay shut.
As for the Vaccum line to the BOV... it is essentially a direct line. The BOV comes with the "Y" gate for the line to the ACV valve.
