Is skipping gears bad?
Old Mar 25, 2006 | 05:33 PM
IcebergS2000's Avatar
Thumbs up Is skipping gears bad?
I was reading in this thread https://www.s2ki.com/forums/index.php?showtopic=372332
and came to the conclusion that skipping gears is bad for the tranny? Is it important to go through each gear while up shifting and down shifting? Can anyone explain what happens that is bad when you skip a gear? Just curious if I understood what I was reading.
Old Mar 25, 2006 | 05:54 PM
xviper's Avatar
This has been discussed in detail by many people, including myself. So as not to repeat myself, I punched in "skip shifting" into the search and came up with all sorts of threads on this.
Try it.
I'm sure you'll find one of my explanations somewhere in those and you'll get to see other peoples' opinions on it as well.
Happy reading.
Old Mar 25, 2006 | 08:20 PM
Slows2k's Avatar
Yes it's bad. Read here: https://www.s2ki.com/forums/index.php?showtopic=237209
Old Mar 26, 2006 | 02:35 AM
Eluded's Avatar
how can double clutching be bad? If everything is spinning at the same speeds its all good.
Old Mar 26, 2006 | 04:50 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Double clutching is pointless. It's not a Mack.
Old Mar 26, 2006 | 05:38 AM
Emil St-Hilaire's Avatar
or a Kenworth.!!!
Old Mar 26, 2006 | 06:32 AM
Wisconsin S2k's Avatar
skip shifting when upshifting is bad. downshifting is ok to skip shift.
Old Mar 26, 2006 | 07:49 AM
apex2k's Avatar
I see this from people who I respect and who know what they speak of, but I still can't buy it wholesale. How can it be okay to come into a hairpin (AP1) with a 30 mph exit speed (regular in auto-x)and jam first gear (and I do mean JAM), when a double-clutch blip, conversely, allows rev-matching and 1st. gear engagement like a hot knife thru butter? This isn't just first with the blocker ring, even a nice 2nd. gear corner feels more like you are working with the car with the double clutch, as opposed to leaning on the stick and waiting for the synchros to do their job that just rev-matching gets you. Hell, it practically sucks it into gear. I don't mean to be a dick, but can a blanket statement like "you never need to double-clutch in a modern manual car like the S" be made? Especially when the S2000 seems to be at its best when the driver and the car work together, rather than trying to beat each other into submission.
Old Mar 26, 2006 | 08:05 AM
because waiting the same amount of time that it would take for you to double clutch would essentially accomplish the same thing. whether you think so or not, double clutching doesn't do anything for a car that has synchros. that's what the synchros are there for. just because you happen to perceive a difference and feel it works better for you, is purely an opinion and based upon your own preference and driving style. keeping this in mind, someone who has the same exact driver skill as you, and doesn't double clutch, will be able to drive the car faster than you. they've learned how to shift the car using the synchros and rev matching, without having to go through the extra motions of the double clutch.
Old Mar 26, 2006 | 08:33 AM
apex2k's Avatar
Understood, thank-you.
