** Help -- I have the POPPING! **
HELLLLLLLPPPPPPPPPPPPPPPPPPPP !!!
I've had this popping sound coming from the rear wheels now for quite some time. I think what is in this post is exactly the problem but I don't have the tools to fix it...
.. any HELP would be so appreciated !!!
https://www.s2ki.com/forums/index.php?showtopic=374070
Thanks guys.........
Q
.. any HELP would be so appreciated !!!https://www.s2ki.com/forums/index.php?showtopic=374070
Q
Had a customer come by the shop about a month ago with the same issue. We fixed him up in a few hours with no parts needed. Depending on the severity of the noise, damage may have already occured then the inevetable would be a higher costly repair.
Call us/PM us and we will help you out.
Could also be pad shift. My S has the same problem. My local honda dealer even replaced the rear calipers and brackets, but it still did not help. When the car is parked, I can slide the rear brake pads back and forth (front to back) within the brackets. My noise is when I hit the brakes, they grab the rotors, and slam into the front of the brackets. I know there are shims that keep the pad off the rotor, but are there a set that keep lateral movement from happening?
I will post some pics this weekend (sunday of course).
I was told tough sh*t, and to live with it from 2 different dealers (as well as the regional service rep).
John
John
John
John
I hope Troy is right and it's covered at Honda. I do have an extended warranty on the vehicle, but I'd rather NOT pay the $100 deductible if I don't have to.
Q
Originally Posted by hygiene boy,Apr 28 2006, 09:39 AM
There is a TSB for it and Honda will fix it for free regardless of warranty.
TSB=Technical Service Bulletin. It is a very common problem with S2000's. The rear axle nuts that keep the drive axles into the rear differential are loosened a bit hence the popping noise when changing direction especially reverse to forward. You have to regrease, retorque and stake the axle nuts assuming no other damage is done. The axle nuts may need to be replaced. Hopefully the splines on the drive axles are not damaged. Regardless of severity Honda has acknowledged this issue and should repair any damage free of charge. Good luck little buddies.
Veilside79
Sep 28, 2008 06:20 AM
robbase
Jul 16, 2002 03:26 PM
