My AEM dryflow modded stock airbox
Old May 1, 2006 | 04:18 PM
DIESELPILOT1969's Avatar
Default My AEM dryflow modded stock airbox
What do you all think?
Old May 1, 2006 | 04:48 PM
iam7head's Avatar
nice, that's like 25% more surface compare to oem filter.
what size btw?
Old May 1, 2006 | 05:32 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
diameter of the intake tube did'nt change.!!!
Old May 1, 2006 | 05:40 PM
I kind of want to retain a stock appearance. Anyhow 7, the filter size is 3.25 inletx 9" overall length. P/N #21-2109DK, Website bought from is: Auto Anything. Also I had to make an adapter to fit inside the filter inlet and intake tube. If you donot have the equipment like I do to make one I would think any fabrication shop could handle it or I can make you one cheap. The stock dimentions are 10.215" lengthX 5" Wide and rolled till the edges meet and rivet together.
http://www.autoanything.com/air-filt...A2591A0A0.aspx
Old May 1, 2006 | 05:44 PM
So???
You can put a filter,the size of a 5 gallon pail,if you don't change anything,downstream,you won't acheive much.!!!
Old May 1, 2006 | 05:54 PM
you can only get so much air through the throttle body. I put the filter on because it takes no oil and can be cleaned and re-used, one time 46 dollar expense, think outside the bun man!
Old May 1, 2006 | 10:32 PM
iam7head's Avatar
Originally Posted by Emil St-Hilaire,May 1 2006, 05:44 PM
So???
it have more more filtering area.
before you ask what will it change, consider this.
it will last longer before it need a recharge
Old May 2, 2006 | 06:31 AM
Wisconsin S2k's Avatar
and even then, it doesn't need to be oiled which is nice.
Old May 2, 2006 | 06:33 AM
mugenrsx's Avatar
Sound/power change with the lid on?
Old May 2, 2006 | 10:07 AM
Red_Devil's Avatar
how about the lid? If you leave it like that, I doubt it will losing HP instead. Beside, when you put the lid back on like OEM look, I doubt this huge air filter will block the air flow tunnel underneath the lid, which is not a good idea either.
If you really want to upgrade the performance and keep the OEM look at the same time, I recommend you just buy K&N 2005 HONDA S2000 2.2L L4 F/I - All, P/N# E-2435.
http://www.knfilters.com/search/prod...px?Prod=E-2435
side not matter, but efficiency & air temperature does!
