UK & Ireland S2000 CommunityDiscussions related to the S2000, its ownership and enthusiasm for it in the UK and Ireland. Including FAQs, and technical questions.
I had my alignment checked yesterday purely for peace of mind after rattling around on some of Scotland's worst surfaced roads over the last 22k miles.
The report I got from St Andrews Honda sadly didn't have the happy green boxes that I have seen on some to show that has been put right - they also appear to have used a customized CR-V setup for starters.
I'm far from technically minded but I can't seem to tie up the final values from the report to anything much from the FAQ - the front camber for instance would appear to be well out, or am I missing something?
The values for an 04 onwards from the FAQ are as follows:
Wheel alignment from 2004 workshop manual
Item Measurement Qualification Standard or New Service Limit
isn't that the problem..
clearly the tech has made a mistake with the target values.. and has been playing all over the place trying to make an S2000 to match a CRV numbers.. which it is not designed to do.... so you are worse off than when you started.
I would ask for my money back and go somewhere else..
I had my alignment checked at St Andrews last year and they gave me a before and after printout that looked very similar to the first sheet in Sarren's post.
Unfortunately I don't have them anymore as I passed them on to the new owner ...
