Wierd EPS and Speedo problem
Old Jun 5, 2006 | 11:56 AM
r_duff's Avatar
Default Wierd EPS and Speedo problem
I changed spark plugs for the first time this saturday. Also tightened my SC tensioner pulley and a routine diff oil change.
I went out on a test drive and after a warm-up and hard run to redline in 1st gear, my speedo displays 0, and the EPS light comes on. Power steering is gone. I turn off the car for 5 secs and start it again. The symptoms persist but go away after 10 seconds of driving.
This happened again sunday after a long drive and run to redline... went away again after i shut off the engine and restarted it.
There are no other symptoms, CEL, nothing... I checked PS fluid, and its full.
Any ideas guys?
Old Jun 5, 2006 | 12:53 PM
jerrypeterson's Avatar
Are you talking about your Honda S2000 or some other car? The S2000 does not have power steering fluid.
Old Jun 5, 2006 | 01:01 PM
r_duff's Avatar
you are correct... i was loooking at the brake and clutch resivoirs, thinking they were PS reservoirs
yes, my s2000
Old Jun 5, 2006 | 01:44 PM
xviper's Avatar
Originally Posted by r_duff,Jun 5 2006, 12:56 PM
and after a warm-up
What exactly did this entail?
I'm beginning to think that anyone who doesn't understand that "EPS" stands for Electric Power Steering and thinks the S has hydraulic fluid in the power steering, may be doing something goofy enough to cause this problem.
Old Jun 5, 2006 | 02:21 PM
Stratocaster's Avatar
OK, you have gears and I assume (Risky I know) you have a Yellow Box. If you lose power to the Yellow Box, or it connections to the speed sensor wire are open on either side (In or output) you will have that problem.
I had an imtermittant connection on mine that took me forever to nail down. I finally just solder them all in place instead of using crimp connectors.
Old Jun 5, 2006 | 04:49 PM
xviper's Avatar
If he does, it sure would have been nice if he had stated this.
Old Jun 5, 2006 | 05:15 PM
SenderGreen's Avatar
You could use the "jumper trick" from the ultimate check engine light thread to retrieve your EPS DTC.
https://www.s2ki.com/forums/index.php?showtopic=378792
Old Jun 5, 2006 | 05:18 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The EPS is speed contingent.
If you have speedo issues, you'll get an EPS light as a result.
I'd start with the YB connections as stated above.
Old Jun 5, 2006 | 10:38 PM
r_duff's Avatar
Thats helpful, ill check my t-taps. i have modifry's yellowjacket.
r_duff's Avatar
i know, but i didnt get a CEL, so i dont think a DTC will come up.
