Close thread
Originally Posted by doheboy6,Jul 24 2006, 02:57 PM
Is that right, only 200HP? I was under the impression that @ stock they were putting out 199-205 hp. Is it tuned? They look sexy though.
Roger, where did you target your AFR to be? Timing? Also, I was curious about your timing maps...I'm assuming your fuel maps are based on TPS vs. RPM, but your timing maps...did also do TPS vs. RPM with a load calc, or does the fuji kit come with accomodations to get a proper MAP signal to do a MAP vs. RPM timing map...
Did you adjust your VTEC engagement point? I'd like to know ALL the details, as you know, I'm waiting to see your results...
I'm hoping 200 rwhp is on a conservative tune...otherwise I'm saddened by the results...
