What tools are needed for a nub working on the S?
Old Sep 25, 2006 | 12:37 PM
KstreetDC's Avatar
Default What tools are needed for a nub working on the S?
I am trying to learn how to work on my S2000 and would like to create my own "garage" so to speak. What do you all recommend I purchase to begin building my supply of tools?
-Will
Old Sep 25, 2006 | 12:44 PM
staticx1134's Avatar
helms manual
Old Sep 25, 2006 | 12:50 PM
Ek9's Avatar
Ek9
Banned
2 torque wrenches, one in inch/lbs, the other in ft/lbs. I wouldn't tighten a single bolt on the car without a torque wrench.
10,12,14,17,19 MM box and open end wrenches and sockets. You can almost disassemble a Honda completely with those sizes.
What are your plans? Oil change level work or heavy maintainance?
Old Sep 25, 2006 | 12:52 PM
KstreetDC's Avatar
I'd like to start with oil change work, but work my way up the ladder until I can do whatever needs to be done to my car.
Old Sep 25, 2006 | 12:56 PM
mikegarrison's Avatar
Aside from the other more obvious things, I really like my dead blow hammer.
Old Sep 25, 2006 | 12:58 PM
KstreetDC's Avatar
Is there a good "starter mechanic" set available from Sears or other stores that sell tools?
Old Sep 25, 2006 | 01:16 PM
Ek9's Avatar
Ek9
Banned
Sure.
As someone else pointed out. Having the shop manual's critical.
Old Sep 25, 2006 | 01:24 PM
KstreetDC's Avatar
Yeah, I was definitely planning to purchase that.
Old Sep 25, 2006 | 01:31 PM
vtec9's Avatar
I'd start with a metric ratchet set, metric box and open ended wrench set, torque wrench, breaker bar. you will also need some misc tools like 23mm (I believe) box wrench and socket to change diff fluid, oil filter wrench. jack + jack stands.
gfacter's Avatar
Here are a few good items to get
Harbor Freight Alum racing jack. The SEARS one won't fit under a lowered car.
Jack Stands
Good quality Screwdrivers (phillips and std)
Impact Screw driver and Rubber mallet
A 3/8 metric socket set (short and long)
A short and long 3/8 socket wrench
Extensions (wobble extensions are handy)
Nice tool box for all the items above
Funnels for fluid adding and clean up
Containers for oil.
Rags for spilled oil
The list goes on........
