this is cool
Old Sep 25, 2006 | 07:34 PM
ShocK's Avatar
Default this is cool
its kinda long but I found it pretty interesting, comments?
http://videos.streetfire.net/search/S2000/...83f0150f005.htm
Old Sep 25, 2006 | 10:09 PM
kane.s2k's Avatar
looks more like you're trying to advertise
It is pretty fast but the greddy type-s used to be one of the faster acting BOV's out there and even with this thing it sounds like there's some compressor surge with their bov at certain points (with the vacuum line connected). Comparing this to the HKS SSQ isn't fair since the SSQ is one of the slowest BOV's out there. The opening also seems fairly small and I would need to see how it performs under very high RPM's.
Also very rare to find one without a diaphram for the vacuum to pull/push and I do like its response speed.
Old Sep 28, 2006 | 05:59 AM
ShocK's Avatar
nah not advertising. just the video is like an advertisement lol. I just found it interesting and wanted to see if u guys thought it was actually a good peice or not
Old Sep 28, 2006 | 10:39 AM
passmans2kny's Avatar
do the tial bovs use a diaphram?
Old Sep 29, 2006 | 12:12 PM
Big_Dawg's Avatar
Looks like the valve is open under vacuum, hence drawing unfiltered air thru the BOV until there is positive pressure...unless I'm missing something. This thing would probably really screw up a MAF based setup.
Old Sep 30, 2006 | 09:03 PM
ShocK's Avatar
well hopefully it has some kind of seal in there
Old Oct 9, 2006 | 01:50 PM
synapse's Avatar
The vid shows the valve in normally open mode just so that you can actually see how fast it actuates. But in production, there'll be a piece that will keep it from sucking in air off-boost, when vented to atmo.
This is a pull-type BOV design. So it is designed to stay shut under boost, no matter what. There is only one other pull-type out there that is used by the masses, the HKS SSQ, which is why it is what is being compared. If you take anything away, it is that you can actually have a fast acting pull-type BOV.
I'm of the opinion that opening diameter isn't ultimately what eliminates compressor surge, it is how fast it actuates once the throttle is closed to negate the sudden pressure rise in the IC piping.
Old Oct 10, 2006 | 08:03 PM
Bigeggroll's Avatar
i'm with Synapse, i don't think the opening diameter has as much to do with how well the BOV prevents compressor surge, but how fast it reacts when the throttle plate shuts. It seems to react pretty quickly. just my opinion anyways.
Old Oct 13, 2006 | 10:32 PM
Phillie's Avatar
Interesting.
Brian339
Dec 23, 2013 08:09 AM
iAhmad
Oct 13, 2012 11:07 PM
MB
Car Talk - Non S2000
Sep 8, 2011 04:24 AM
MID ISLE S2K
Vancouver Island
Jan 26, 2010 07:39 PM
HighwayStar
Jun 12, 2007 02:01 PM
