The fifth to fourth shift
Old Sep 27, 2006 | 04:06 AM
Purple Haze's Avatar
Default The fifth to fourth shift
Hi. I think one of the most crucial shifts is the one going from fifth to fourth. The technique on this shift is very important because an error can lead you into second gear.
I find that the best way to go from fifth to fourth is to first guide the shifter into neutral, and then remove my hand, reverse my hand into a backhanded position, and then guide the shifter into fourth. This way I prevent myself from going into second.
How do you do it?
Old Sep 27, 2006 | 04:19 AM
Conedodger's Avatar
I just lightly pull it back with my fingertips and let the centering springs do their job. IMHO, it is one of the easier shifts.
Old Sep 27, 2006 | 04:20 AM
AssassinJN's Avatar
Old Sep 27, 2006 | 04:28 AM
spdemon12384's Avatar
I agree too. Once u let the stick out of gear, there are springs that move it into the center (between 3 & 4) so all you have to do is pull down.
Old Sep 27, 2006 | 04:31 AM
carlit0sway's Avatar
i think the hardest shift is into reverse
Old Sep 27, 2006 | 04:33 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
How do you do it?
Why go through all these motions???
Just get a RPSS.!!!
Old Sep 27, 2006 | 06:22 AM
notyou's Avatar
Centering Springs!
Use 'em.
Old Sep 27, 2006 | 06:26 AM
nightcrawler7188's Avatar
position your hand over the knob palm down and fingers in front of the knob. knock the knob down into neutral, let the springs center it, and knock it back down into 4th. If you just use your fingers instead of gripping the knob it's faster and easier to do right. btw there's no pause between knocking it into neutral and then down into 4th. do it all in one motion.
Old Sep 27, 2006 | 06:36 AM
Saki GT's Avatar
Don't try and fight with the shifter - once you know how it behaves, getting int all the gears is easy imo. Going from 5 to 4, just get pressure on the front of the shifter and it will center and go into 4 easily. Don't try and pull it - that's when you work against the springs and end up in 2nd at 70mph.
Old Sep 27, 2006 | 06:39 AM
Conedodger's Avatar
Too many people man handle the shifter. All it needs is a little left pressure for a shift to 1st or 2nd. A little pressure forward or backwards to allow the centering springs to do their job for 3rd and 4th. A little right pressure for 5th and 6th.
I agree with carlit0sway, the shift to revesre is the hardest!
