cel: P0411
Old Oct 4, 2006 | 11:52 PM
j03chu's Avatar
Default cel: P0411
its the one that you get after installing aftermarket intakes. the first time it came on was because i put on the check valve backwards=P. fixed that, cel went away after a few driving cycles..
after a couple weeks, cel came on again.. got it pulled @ autozone.. same code, checked everything.. after a little bit the personnel said that he reset the code? and it went away..
after a day, at night, cel went on again.. didn't have time to pull code but.. ;[. any ideas?
Old Oct 5, 2006 | 12:13 AM
Enthralled's Avatar
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
are you sure it's not P0411....?
P0411 Secondary Air Injection System Incorrect Flow Detected
Old Oct 5, 2006 | 12:17 AM
Enthralled's Avatar
If it is P0411 thats means one of your vac lines are loose.
Make sure all your lines are connected
https://www.s2ki.com/forums/index.php?showtopic=105368
Old Oct 5, 2006 | 12:27 AM
j03chu's Avatar
o yea that one!!! thanks alot for the fast reply. mmm they are.. but i'll take pictures to show u
Old Oct 5, 2006 | 12:30 AM
Enthralled's Avatar
look in the link above...it shows how they are suppose to be connected.
Old Oct 5, 2006 | 01:12 AM
j03chu's Avatar
i pretty sure its connected right. just dunno why the light still comes on.. guess i'll get it pulled tomorrow again to check if its the same code or not.mm i DID buy new tubes for the hoses for installing the intake. what if the vaccumm hoses are leaking? not tight? will that make the cel?
Old Oct 5, 2006 | 01:21 AM
Enthralled's Avatar
yes they all have to be tight and connected.make sure they are connected in the right place.take a look at the link and make sure everything is the same.
Old Jun 3, 2012 | 02:07 PM
jtsimaras's Avatar
Hi I know digging old post up--but I'm having the same issue -- can you update the link as it is not working.
Thanks
Old Jun 3, 2012 | 03:33 PM
s2klariat's Avatar
Google is your friend
hrpfg2
Jan 11, 2010 08:41 PM
Mister Jew
Mar 13, 2007 09:45 PM
kuyabil
Apr 14, 2006 05:55 PM
