best "single body" suspension system for racing?
I didn't realize NASA would make me add weight due to the KW3's reserviour..... so I am going to remove them and put something else on. I already have to weight 2800 due to the 2.2L engine.....
anyone have any suggestions. i was actually fine with Tein RA's on my previous car but i am sure there is something better for a "reasonable" price ????
I don't want to spend $1k per corner....
thanks.....
thanks.....
Good question. I've known folks that were reasonably happy with the Tein RA setup so it may be a good compromise.
Anyone ever heard feedback on the KWV2 setup? If you're happy with the KWV3, then I'd look into those as well.
Bilstein PSS9? I'm not sure if it's remote reservoir or even has a sufficient damping range to do well on the track.
Does JRZ do a single body shock? Probably $$$ if they do?
Keep in mind some of the single bodies with a wide damping range could be able to match higher spring rates and/or could be custom-valved. In this scenario, your budget objective may be unachievable.
**EDIT: Just checked the Tein site and the N1 is a single body racing damper. Price = $2800 MSRP about the same as the SRC.
Tein N1
Tein N1
That's easy. KW competiton's. They are an upgrade to the V3's, you can run high spring rates, aka 800-1100lbs if needed/wanted, and have no remote.
Dave Karner used them, so they can't be all bad. I think they run $2800 list.
JRZ also does the RS versio for about 3K without remote. It's a double and adjusts just like the Kw's.
Scot,
The Koni 28 series are a monotube shock with no reservoir. They will not fit in the budget you suggested, but are the best option you have.
However...
The non-reservoired JRZ singles are not in the same league as the reservoired ones. Honda Challenge needs to emerge from the dark ages with their suspension restrictions (among others). Have you thought about petitioning the regional sanctioning body? I bet that ruling was made with the intention of keeping costs down (abject myopia?). Since you can't find anything off the shelf that will work really well, you'll either be potentially spending as much on non-reservoired shocks without the benefit of the reservoirs, or purchasing inferior non-reservoired shocks that are slower.
Glad you are back.
Asura
However...
Glad you are back.
Asura
Originally Posted by jlucas,Oct 16 2006, 06:16 PM
Got to love the Koni 2812s.
