Oil seeping from diff mounting point
Old Jan 22, 2002 | 01:37 PM
SaV's Avatar
SaV
Default Oil seeping from diff mounting point
I really need some help. One of the mounts that holds up the differential is leaking oil. It is the side opposite where the propellar shaft eventually leads into (the side facing the rear of the exhausts). The diff is bolted onto a subframe and then that subframe is bolted on to the cars chassis. The part where chassis and the subframe are connected is leaking oil. In fact, it stopped after 2 weeks of leaking. Should this mount have oil at all? I brought it to Honda and they say it is from a previous oil change (they might have looked at the differential specifically and not the mount, since I changed the diff fluid one week ago). Anyone have any thoughts?
Old Jan 22, 2002 | 02:06 PM
cdelena's Avatar
Those big rubber mounts sure appear to contain an oil damper.. there are stains on my exhaust system that look like mine was leaking. It is an expensive part (over $75) so maybe there is more to it than rubber. Has anyone take one out and examined it?
Old Jan 22, 2002 | 08:26 PM
SaV's Avatar
SaV
Anybody ? Well. . .to the top we go.
Old Jan 22, 2002 | 08:49 PM
Austin_S2000's Avatar
Yes they do contain oil for dampening. I had the same problem a long time ago on my early 2001 model. Attached are some pics for you to look at.
This was all covered under warranty. You should take it in.
-- Jose
Old Jan 22, 2002 | 09:30 PM
SaV's Avatar
SaV
This is exactly the same part that is leaking on my S ! Got to call my service manager and get that part in. Thanks Austin (how's the shift knob?). Latez!
Old Jan 22, 2002 | 09:33 PM
Glad I could help. Really like the Ti knob. Like the heavier feel and color.
Yeah get it fixed. It was strange that it happened. Maybe a rock hit...I really don't know. The techs were very puzzled and had to call a Honda tech service to see if they had any ideas. They didn't make a big deal out of it.
-- Jose
i77ac_10
Mar 18, 2010 06:03 PM
EireannS2k
Jun 5, 2009 09:32 AM
rickw06
Mar 21, 2009 01:18 PM
noizyboyz
Jul 2, 2008 01:27 AM
WhiteS20000
Oct 23, 2007 07:46 AM
