Spoon Calipers
Old Nov 13, 2006 | 02:32 PM
midnightmethane's Avatar
Default Spoon Calipers
I've got a serious craving for Spoon calipers....will they fit AP2 wheels and if so with what size spacers??....where is the best and cheapest place to buy the calipers and the spacers
will they fit the oem rotors and the SubZero rotors
also I installed goodridge lines on oem calipers...will I be able to use those lines on the Spoon calipers...
one more thing can you guys name any other aftermarket calipers that satisfy the same criteria?
i'm praying for some positive feedback....thanks in advance!!!!
Old Nov 13, 2006 | 03:31 PM
jonathanschley's Avatar
cheapest place to buy them is Bulletproof Automotive... by a long shot. their group buy on them is for $1475 shipped. the cheapest i found them anywhere else was invision at $1520... but Bulletproof has them in stock. furthermore, pad and rotor fitment is the same as oem. i don't know what spacers you will need but i am sure they would work with spacers, i just don't know what size and make sure they are hubcentric. also...depending on how big of a spacer you need, you may have to roll your fenders. but thats no biggie.
Old Nov 13, 2006 | 04:12 PM
cool...i need to know the size of the spacers....hopefully they'll be 5mm....will i need more than that for AP2 OEM wheels??
probably closer to 10-15.
Old Nov 13, 2006 | 04:29 PM
ouch......that's crazy...that's really gonna screw up everything
what about the stoptech one with 13 inch rotors...here is the link:
http://stoptech.com/user/SearchResults.asp
Old Nov 13, 2006 | 06:15 PM
it's going to be like that with any brake kit except the wilwood 4 pot. the brembo calipers are the smallest.
Old Nov 13, 2006 | 07:02 PM
so brembos and willwood are doable, but with what size spacers??
i def. could do brembo...expensive but very nice
Old Nov 13, 2006 | 07:07 PM
which model willwood are we talking about...i've got the link here:
http://www.wilwood.com/BrakeKits/index.asp
just tell me which one and the probable size of the spacer needed for AP2 OEM wheel...thanks
Old Nov 13, 2006 | 07:33 PM
AP2F22's Avatar
i believe brembo and most bbks are about 15mm and wilwoods are about 5-8 mm.
