FI Guys - What's your gauge setup?
Old Dec 28, 2006 | 10:29 AM
Akilldema's Avatar
Default FI Guys - What's your gauge setup?
Pics and manufacturer/vendor would be ideal. I need to decide what kind of setup I'm gonna do when I get everything finished.
Old Dec 28, 2006 | 10:56 AM
OGPackin's Avatar
Defi all the way...
Boost, Oil Preasure, and Water Temp...
Old Dec 28, 2006 | 12:46 PM
Spec_Ops2087's Avatar
Nordskog digital gauges -- Oil and water temp, EGT, oil pressure
Apexi EL series -- Fuel pressure and boost
Supercharged....
Old Dec 28, 2006 | 01:28 PM
WindchaserS2K's Avatar
AEM Serial gauge and Boost gauge
Old Dec 28, 2006 | 01:29 PM
CourageOO7's Avatar
Defi Boost and EGT. Defi FTW! The control unit is el bombo. AEM Wideband soon to come!
J
Old Dec 28, 2006 | 02:52 PM
John_Z's Avatar
I'm running Auto Meter Ultra Lite gauges. Boost and EGT on the A-pillar, oil pressure in the radio door.
Old Dec 28, 2006 | 03:34 PM
Akilldema's Avatar
I hadn't thought of mounting one on the radio door. How easy was that? Did you DIY? I need somewhere to put the EUGO gauge type sensor, boost gauge and oil pressure. Is there anything else I really need?
Old Dec 28, 2006 | 03:49 PM
John_Z's Avatar
I did not make a DIY, but it is very simple to do. You will obviously lose your radio. Just pull the radio door and trim, remove the radio, cut the hole with a hole saw then wire it up.
An EGT gauge would be nice to have. I did not want to run more than 3 gauges and this was the best setup I could concoct.
Old Dec 28, 2006 | 04:10 PM
s0rted's Avatar
Not necessarily if you use low profile gauges.
Boost and oil pressure, Blitz DCII's:
Also, PLX R500 in passenger's side pocket.
Old Dec 28, 2006 | 04:42 PM
Akilldema's Avatar
Nice! That would be perfect.
