Clutch pedal is weird..
Old Jan 5, 2007 | 06:59 AM
cmn's Avatar
cmn
Default Clutch pedal is weird..
My clutch pedal is just weird... It's normal when I press the clutch pedal in, to put the car in gear/change gear, but when I release the pedal, it feels like it goes out in 2 steps.. Hope someone understand what I mean. Is it ok, or is it bad? How can I fix it? Changed the clutch 5000km ago.
Old Jan 5, 2007 | 11:05 AM
slalom44's Avatar
Top Answer: 1
My guess is that the garage that installed your clutch didn't lube the release fork adequately. It's also possible that the splines on the shaft the throwout bearing rides on didn't get enough grease but since you don't have any problems pushing the clutch in, this should be fine. And since you're not mentioning any wierd noises, I'd assume the clutch plate is fine.
The good news is you can lube the release fork without removing the transmission. I'm not familiar with this procedure since I haven't done this myself but if you do a search, you will find several threads on the subject.
Other things to look at:
  • When you had the clutch replaced, did they replace the throwout bearing (also called a release bearing)? If not, let us know.
  • Check the clutch fluid to see if the level is not low and the fluid inside isn't black. There is an outside chance that your master or slave cylinder is binding, and it wouldn't be a bad idea to flush & replace your clutch fluid.
Old Jan 5, 2007 | 11:11 AM
slalom44's Avatar
Top Answer: 1
Here's another thread on the subject:
https://www.s2ki.com/forums/index.php?showt...0&#entry3992848
Old Jan 5, 2007 | 11:52 AM
cmn's Avatar
cmn
Thanks a lot! I'll check the fluid level and color as soon as possible. Any other tips? No sounds btw!
Old Jan 5, 2007 | 03:33 PM
SpitfireS's Avatar
Have a read here:
https://www.s2ki.com/forums/index.php?showt...70792&hl=sticky
and here:
https://www.s2ki.com/forums/index.php?showt...l=clutch+dbzerk
Old Jan 8, 2007 | 01:44 PM
cmn's Avatar
cmn
But it's safe to drive with it for a while (until I can fix it)?..
Old Jan 8, 2007 | 03:20 PM
melonheadr6's Avatar
Originally Posted by SpitfireS,Jan 5 2007, 04:33 PM
Spitfire saved me from going crazy with that first link. Thanks AGAIN man!
Old Jan 18, 2007 | 08:29 AM
REVZ TO9's Avatar
Banned
I had a similar problem and it ended up being my clutch fluid leaking and needed new clutch cylinders
Old Jan 18, 2007 | 01:08 PM
dbzerk's Avatar
Check out my thread...
mezzfin
Nov 11, 2010 02:51 PM
tngay510
May 10, 2010 05:33 PM
Suits
Mar 7, 2010 02:11 AM
rikhemi
Sep 10, 2007 06:29 PM
sheepdin
May 21, 2007 11:43 AM
