Where to race your S2K
Just a short post. I'll update this later. If you want to write a description of the class and write a list of what mods are allowed etc that would be appreciated. Otherwise I'll work on them myself.
United States
SCCA:
T3 s2k new for 2007+, was in T2 in -2006
- Mostly stock, mods are expensive because of lots of rules.
- Only class where you can take a s2k to the National Run-Offs
- Base allowed mods and common recommendations.
-- 28??lbs
-- AP1 or AP2 oem wheels (USDM not JDM) :: AP2 Wheels
-- DOT Tires (RA1, Hooiser, Kumho, etc)
-- Full Interior
-- Stock Brakes
-- Stock ECU
-- Double Adjustable Shocks with OEM springs :: Moton, JRZ, Peneske
-- No Wing
ITR new for 2007+
- A lot less stock than T3, but still a fair number of rules on what you can/can't do.
- 30??lbs
-- Any wheel up to 17x8.5
-- No ABS
-- Stock Brakes
-- Stock ECU (ITR rules make it impossible for S2K to change ECU, other makes can tho)
-- No Wing
-- Dash & Heater Box Required
-- Double Adjustable Shocks w/ Any spring, No remote reservoir.
Honda Cup (souther cal/arizona only currently)
- Pretty open on mods but still some weight, tire, and other limits.
-- 2.0L 2550lbs - 2.2L 2650lbs
-- 255x4 or 245F/275R w/ +100lbs
-- Programmable ECU allowed, Engine mods allowed
-- Aero/Wing allowed
ITE
- Anything you want to do w/ a s2k.
NASA:
Honda Challenge H1 (NASA)
Canada
CASC-OR
Super Touring (ST) - - Canadian Touring Car Championship - Ontario Canada only
- ~2400lbs incl. driver
- 245 width RA-1 tires (spec)
- 9" wide wheels max
- Wing allowed but restricted in size and position
- No FI mods
- Most other mods open except aero
- some mods may increase minimum weight allowance (brake diameter/# pistons)
- rewards weight based on finish position
United StatesSCCA:
-- 28??lbs
-- Full Interior
-- Stock Brakes
-- Stock ECU
-- No Wing
ITR new for 2007+
- 30??lbs
-- No ABS
-- Stock Brakes
-- No Wing
ITE
NASA:
CanadaCASC-OR
- No FI mods
Originally Posted by krazik,Apr 28 2007, 10:33 AM
why? its a litttle high right now and that will get sorted but it's to keep the cars in the class on an close to equal pace.
