Dutch turbo
Old Jan 22, 2007 | 01:20 AM
YuriArts's Avatar
Default Dutch turbo
last weekend I made a plan with my tuner for installing the InlinePro turbo kit on my NFR Honda S2000. My NFR in 'The Gallery' forum
We are aiming for 1.5bar (approximately 450whp i think) with a very driveable car on 0.7 - 1 bar.
How do we think to do so?
- GT3076, 82 AR Ball bearing turbo
- low boost: 0.7 - 1.0 bar on normal 95 octane gass (europe) on 1 set of injectors.
- high boost on race gass (1.0 - 1.5 bar) on 2nd set of injectors
- lowering the compression with a 2mm gasket to 10:1
- dual fuelrail system, we are fixing the 4 extra injectors on the intake manifold
- AEM 1012
- AEM Peak Holder
- Extra fueltank for the race gass
- New clutch, Competition Ironman
I have some question though to know if we are going the right way:
1. Which injectors will we need for max 1.0 bar? 440cc ?
answer: 675cc apparently
2. Which injectors will we need for max 1.5 bar? 800cc ?
answer: 880cc should be enough
3. High boost will be running on C16 race gass (128 octane). Will 1.5 bar be safe with the compression of 10:1 ?
answer: hopefully Yes
6. Which fuelpump can I get for pumping the race gass from the back to the motor compartment? Walbro? Because the kit comes with a
Old Jan 22, 2007 | 04:30 AM
GDM S2K's Avatar
first a question-
how much power are you shooting for?
with running that turbo you should only really need a set of 1000cc injectors for low and high boost. the 1000"s should support up to 550-600 safetly.
what kind of c16 are u planning on using? I believe its 117 octane not 123 you may be thinking of VP import
Old Jan 22, 2007 | 05:32 AM
YuriArts's Avatar
Originally Posted by GDM S2K,Jan 22 2007, 05:30 AM
first a question-
I'm shooting for approx 450whp on high boost (1.5bar). I don't know what the result will be exactly but we want to go low and high boost.
I need more injectors because of the race fuel. With the normal fuel I want low boost. When I flip a switch the GM boost solenoid will make it 1.5bar and add the 2nd set of injectors.
This way I hope the car will be more drivable. The smaller the injectors, the more precise the fuel management is. I'm getting a AEM Peak holder injector driver anyway but 1000cc would be overkill.
What's VP import? The only kind I know of we have in Holland is C12 and C16.
Old Jan 22, 2007 | 05:47 AM
GDM S2K's Avatar
you could make 450 safe on pump gas,
Old Jan 22, 2007 | 06:56 AM
YuriArts's Avatar
the whp isn't really important, it's the 1.5bar that we want without lowering the compression too much.
With the 2mm gasket the compression is going to 10:1 i guess. Will the engine hold that on 1.5bar and pump gas?
By the way, how much PSI is 1.5bar? Anyone know the calculation?
Old Jan 22, 2007 | 06:57 AM
GDM S2K's Avatar
21 pounds I believe which is alot. you could prob make you hp by 15 psi
Old Jan 22, 2007 | 07:00 AM
YuriArts's Avatar
Damn, that's a lot
We're actually aiming at the 1.5bar (21psi) and see how much whp we get.
450whp would be nice.
Old Jan 22, 2007 | 09:31 AM
DrBelmore's Avatar
Actually its 22.05 psi because 1 bar = 14.7psi
Old Jan 22, 2007 | 12:14 PM
YuriArts's Avatar
14,7psi. Will the engine hold that in the setup I described on normal gas??
Only change on the motor will be the 2mm gasket.
Old Jan 22, 2007 | 01:10 PM
Quivers's Avatar
Banned
your making this to complicated, you can make 450 so easy without all this crazy hassle your talking about, plus I don't think the gt30 is good for any more than 450whp and you only need 14 to 16psi to make that.
