Sponsored by:
Sponsored by:
OZ ULTRALEGGERA
Old Jan 31, 2007 | 01:17 AM
TommieB's Avatar
Default OZ ULTRALEGGERA
Do ET 48 fit in the( 8" )front?
Rearwheel ( 9" )must work with ET 55... or am I totaly off?
/Tommie
Old Jan 31, 2007 | 07:19 AM
sprix!'s Avatar
Sounds safe to me. There is another guy in Atlanta who is running that same setup, I believe. Patrick, deafpimp- you out there?
Old Jan 31, 2007 | 08:38 AM
Jim@tirerack's Avatar
I have sold a number of these wheels on the S2K. You can go 225/40R18 and 245/35R18 no problem. You can also go with 255/35R18 but depending on the alignment setting on the car you may need a little more negative camber.
If I can help let me know.
Old Feb 1, 2007 | 12:19 AM
TommieB's Avatar
Thanks Jim!
Old Feb 1, 2007 | 12:09 PM
Blendo's Avatar
As a side note to these OZ Wheels on the S2000, would I be able to fit a Falken Azenis RT-615 265/35R18 in the rear?
Section width is 10.7 inch
The same tire with 255/40R18 size has a 10.3 width.
ideas?
Rolling fenders or moving the bumper bracket shouldn't be a problem for me. Car will be mostly stock, no big power adders... but will be autocrossed and tracked a fair amount this summer. Stock suspension for now, with a Tein Flex upgrade in Summer.
Old Feb 1, 2007 | 01:56 PM
I would say no to the 265 tires. I have seen 255/35R18 fit though.
Old Feb 1, 2007 | 07:53 PM
HeyDanNiceShot's Avatar
I'd like to get that setup with a 255/35-18 rear. What's the screaming deal Jim? Send me a PM!
Old Feb 1, 2007 | 08:10 PM
GrandMasterKhan's Avatar
anyone have photos? i would love to see some!
Old Feb 1, 2007 | 10:29 PM
You can check them out on the car on www.Tirerack.com
Here is the wheel:
Old Feb 1, 2007 | 11:20 PM
Blendo's Avatar
Hi Jim,
Thanks for answering my question in this thread. https://www.s2ki.com/forums/index.php?showtopic=458418
I have a couple more for you. To allow better fitment and tire choices, I'm going to use the OEM 17 inch wheels of my 2004 S2000 for the track. For a summer/daily driver setup I still want to purchase the Ultraleggeras in a 18" set for the S.
To make things easy, I will also buy tires and have them mounted by you guys
Good choice for Midwest Spring Summer Fall tires sounds like the Goodyear Eagle F1 GD-D3s. Fitment for the the rear can be 255/35ZR18 correct? The wheels with a 9.0 inch rim should handle the 10.2" section width of the tire? Am I looking to add a little more camber and/or will fender mods be required?
Everyone says the fronts can be 225/40ZR18 without issues so that should be ok.
That should be it for now. I see some of the tires are not in stock but will be in about 2 weeks. Thats fine for me. I'm just waiting for my tax return to show up.
Have a good night,
Chris
