re-setting EPS
Old Feb 14, 2007 | 10:33 PM
dbzerk's Avatar
Default re-setting EPS
Does anyone know how to reset the EPS so that you can 'teach' it where the center position is?
Thanks
Old Feb 14, 2007 | 11:07 PM
SpitfireS's Avatar
Its not a bad idea to find yourself (or buy ) a service manaul.
Old Feb 14, 2007 | 11:55 PM
dbzerk's Avatar
Is there a way to do it without a PGM tester???
Old Feb 15, 2007 | 10:58 PM
dbzerk's Avatar
anyone???
Old Feb 16, 2007 | 12:37 AM
SenderGreen's Avatar
Use a paperclip or jumper wire in place of the PGM Tester. Jump Pins 4 and 9 on the DLC. Like they show here http://www.k-series.com/tech_detail.php?Tech_ID=CEL
PIN 9 is the SCS wire and PIN 4 is the Chasis Ground. Follow the directions as normal from that point on.
Old Feb 16, 2007 | 04:36 AM
Stratocaster's Avatar
I have done it a few times on my S with a paperclip. Worked like a champ.
Old Feb 16, 2007 | 07:12 AM
ottokrat's Avatar
Can you please describe what if feels like to need the reset procedure?
My situation is as follows:
I recently had some suspension work done and afterwards the steering wheel was just a bit off center, to the left. I also noticed that the steering had a notchy feel at initial turn to the right, kinda where it used to be centered, but is otherwise smooth. I had it aligned (not at dealer) and now the wheel is straight, but I still have that notchy feel rigth at initial turn to the right.
Does this sound like I need EPS reset?
Old Feb 16, 2007 | 08:39 AM
ottokrat's Avatar
Also, it doesn't seem like the simple SCS jump works for EPS reset on '06 model.
The '06 shop manual inserts and extra step that says the PGM tester must be communicating for '06 model.
When trying the jumper-wire version of reset procedure on my '06, I can tell the SCS is jumped as other dashboard lights come on and flash differently than w/ just key to ON(II). However, the EPS light will not turn off after any duration.
The EPS light only turns off after car is started - which I didn't try with SCS jumped (don't know if that could be bad, and instructions never say to start the vehicle/engine).
Shoot. Looks like a trip to the dealer is needed for this simple reset on '06.
Old Feb 16, 2007 | 05:47 PM
[QUOTE=ottokrat,Feb 16 2007, 09:39 AM] Also, it doesn't seem like the simple SCS jump works for EPS reset on '06 model.
Old Feb 17, 2007 | 07:21 PM
dbzerk's Avatar
I think the Australian model cars don't have those plugs...What now!? lol
