Non-Stagger, Oversteer
I went with a non-stagger setup and I knew I would get oversteer. Just wondering what others have done to reduce it?
17x9 +63 Buddy Club QF's all around with 255/40/17 Azenis 615's
Tein Flex coilovers
Mainly autocross right now. I lowered air pressure and it helped a bit. What other things can I do.
I read a thread about removing the rear sway bar? Beneficial for a non-stagger set up?
Plan to get a alingment so that is on the list already. Just trying to get this set up going.
James
Tein Flex coilovers
James
What can I expect running 235/40R17 RA-1s on all corners wit 8.5" +50 Volk RE-30 wheels? I'm going to guess major oversteer and am planning to use a Mugen front bar and disconnect the rear bar to try an balance it out. Will that be enough?
I'll have 110Nm rear springs and 120Nm fronts on Ohlins shocks.
Originally Posted by krazik' date='Mar 19 2007, 11:17 AM
get rid of the buddy clubs? How much did you slam the car? I bet you're bottoming out in the back. If you don't get rid of the shitty shocks, put the car back to stock ride height.
Originally Posted by krazik' date='Mar 19 2007, 01:38 PM
Sorry Buddy Club wheels missed that. The teins will have less of an issue bottoming out. You didn't answer my question tho.
but maybe not.
Originally Posted by vvs' date='Mar 20 2007, 07:51 AM
Well the fronts are approx 1.5 inch lower, cant go too low with the 255's up front. The rear is approx 2-2.25 inches lower. It seems I have enough "stroke" up and down
but maybe not.
but maybe not.
but maybe not.
but maybe not.
