recaro spg help!
Old Apr 28, 2007 | 08:19 PM
kikicha's Avatar
Default recaro spg help!
Hi i have a few questions. I was under the impression that the normal spg would not hit the door panel, i'm on a buddy club rail, front is on 3 (middle) and rear is on the 1st (lowest). I did put some washers between the door panel insert which probably gave me an extra 1-3mm more space but still rubs Would shaving down that long triangular foam piece help(between the actual door and door panel)
any advice is greatly welcomed!
edit- I also put one 1mm washer between where the rail and the seat makes contact to prevent marks and stuff.
Old Apr 28, 2007 | 09:10 PM
mikegarrison's Avatar
You were under a mistaken impression. You can get the SPG in without hitting the door trim, but only if it is mounted a little off center (towards the tunnel).
Old Apr 29, 2007 | 12:34 PM
RWD_RCKT's Avatar
The only SPG I have seen NOT rub is when they filed down the seat where it rubs. Even 3 mm would still rub. Mine rub like CRAZY, I have tried everything from spacers, to moving the rail, to changing rails (from Recaro rail to Mugen)... but I didn't want to file the seats down because the fabric looks loose around there.
But if someone has a solution I am all ears!
Old Apr 29, 2007 | 03:30 PM
[QUOTE=RWD_RCKT,Apr 29 2007, 01:34 PM] The only SPG I have seen NOT rub is when they filed down the seat where it rubs.
Old Apr 29, 2007 | 05:13 PM
Slows2k's Avatar
My SPG-N doesn't rub the door panel or block the console. It's also mounted on custom built brackets on a Taitec rail, and I don't sit with the seat as far back as possible.
Old Apr 30, 2007 | 02:54 PM
kikicha's Avatar
hmm this really sucks.. we'll i'm determined to get this to not rub! if i get something to work out i will do a little step by step thingy
Old Apr 30, 2007 | 08:47 PM
cuonice's Avatar
I have a Recaro SPG mounted on Buddy Club rail and I too rub the door ever so slightly. I'd just shave a couple millimeters off the shoulder bolster.
Old May 1, 2007 | 07:25 AM
kikicha's Avatar
i would do that too, but its too hard for me to hack up my new seat
Old May 10, 2010 | 10:08 PM
trinydex's Avatar
did anyone here ever try heating the back of the door panel and then pushing the door panel in, to make a little smooth divot for the seat to sit in... if you were so inclined you could make the divot cylindrical so you can slide you seat back and forth still...
or maybe the door panel is not structured internally so that is possible?
bubsie007
Jun 2, 2011 05:44 PM
macr88
Interior
Jan 14, 2010 09:55 PM
RL428
Dec 6, 2008 06:03 PM
DongTran
Aug 26, 2005 08:01 AM
cheshire_carper
Jul 7, 2004 11:46 AM
