T1R Strut Tower Bar
Old May 13, 2007 | 11:45 AM
sabry's Avatar
Default T1R Strut Tower Bar
Hi guys,
I would like to install a a strut bar on my car to go on the track, what do you think about this one:
http://cgi.ebay.com/ebaymotors/T1R-Strut-T...114800522QQrdZ1
Thanks in advance
Sabry
Old May 13, 2007 | 11:58 AM
krazik's Avatar
Administrator
We don't have struts. Save your $.
Old May 13, 2007 | 12:14 PM
sabry's Avatar
Can you give some advices for the chassis?
What do i need to do or not do ?
Sabry
Old May 13, 2007 | 12:33 PM
krazik's Avatar
Administrator
nothing needed there. if its your first track day just go drive the car.
If you haven't had one recently spend the $ on an alignment.
-Ry
Old May 13, 2007 | 01:13 PM
sabry's Avatar
[QUOTE=krazik,May 13 2007, 09:33 PM] nothing needed there.
Old May 13, 2007 | 02:50 PM
cuonice's Avatar
Originally Posted by sabry,May 13 2007, 01:13 PM
I took my S on the track and i understood directly that i need to change some parts on my car like the suspension, the brake rotors and the pads.
Pads, fluids, YES. But you do not NEED aftermarket suspension, or a "strut bar." Its your car and you can modify it as you desire, but as far as tracking the car the modifications you are asking about are far from necessary.
If you do wish to add modifications to the car, you may consider starting with a seat and a roll bar. I'm sure in the future you'll get a better idea of what you want and you wont have to ask us.
Old May 13, 2007 | 04:50 PM
Trent06's Avatar
i would say that is probably a good setup since t1r is a reputable company, it looks like a great price for both strut bar and x brace
Old May 13, 2007 | 08:31 PM
AP2's Avatar
AP2
that is a PITA to install...i would assume it stiffens up the chassis a little because it was pretty difficult to get all 4 pts. to where they needed to be.
Old May 13, 2007 | 08:42 PM
krazik's Avatar
Administrator
unfortunately thats an incorrect assumption.
because it was hard to install means its good?
Old May 13, 2007 | 09:51 PM
mikegarrison's Avatar
Originally Posted by sabry,May 13 2007, 02:13 PM
I can't modify my car in Belgium because it's not road legal so i decided to buy another S2K for the track.
I would like to take out almost everything in the car to reduce the weight, i will change the suspension, the brake, the exhaust, the airbox and i would like to upgrade the chassis.
That's why i need some advices from guys like you who have a lot of experience with the S on the track.
I would be very grateful if you can give some advices on the parts (best bang for the bucks) to purchase for the beginning.
OK then, here is the collected wisdom I have seen in this group over the past 4-5 years regarding suspension and chassis:
Weld in a roll cage. That will get you all the chassis stiffness you could ever want, and also add to safety.
Don't screw around with bolt-on braces. They are not worth the weight.
Seam weld the upper A-arm brackets.
Buy a nice set of coilovers, and maybe an anti-bumpsteer kit if it's an older car.
Remove the softtop.
Add a wing and a splitter.
Check/replace the A-arm bushings.
Consider changing out the anti-roll bars (but this depends a lot on your other choices.
