Squeeky noise coming from rear.
Old Jun 18, 2007 | 04:55 PM
Kenpo_S2000's Avatar
Default Squeeky noise coming from rear.
I have a squeeky noise coming from my rear passenger side. I don't think it is my shocks because the ride is not bouncy. I have Eibach springs and stock shocks. Could something just need lubricated? Please Help.
Thanks.
Old Jun 18, 2007 | 05:25 PM
black2000's Avatar
I've got the same issue and I just have the stock suspension. I took a mechanic for a ride and he said it needed some lube in the suspension bushings. I thought I had a much bigger problem. I still haven't gotten to it yet so I can't say if he was right or not...
Old Jun 18, 2007 | 05:39 PM
slanguage's Avatar
I had a similar problem. The hub area where it meeets the axle might need to be lubricated. Also check under the CV joint boot and make sure that is also got plenty of grease and make sure there is no rust around the hub etc.
Mine did this on the drivers side rear, and it didnt matter if I was in gear or not, or if I was on the brake or not
Old Jun 18, 2007 | 05:46 PM
Thanks for the replys I will have to take it to see if they can lubricate those parts. It's not really loud but it's getting really annoying. I just hope its nothing serious.
Old Jun 18, 2007 | 10:49 PM
RACER's Avatar
Old Jun 18, 2007 | 11:38 PM
B.Money's Avatar
lol well let me know if this fixes the problem. I have the same thing and havent lubed anything in awhile.
Old Jun 19, 2007 | 05:36 AM
Originally Posted by RACER,Jun 18 2007, 10:49 PM
Old Jun 19, 2007 | 10:11 AM
TrackStar's Avatar
Mine was caused by a worn out ball joint in the rear knuckle.
Old Jun 19, 2007 | 10:23 AM
ctmugen's Avatar
I just had the same exact problem checked at the dealer. They told me the rt axle nut needed to be re torqued.
I just got the car back but it seems to have cured the problem, no more noise.
Old Jun 19, 2007 | 10:32 AM
TrackStar's Avatar
If you push down on the trunk or quarter and it sounds like a worn out mattress it is probably the ball joint, as it was in my case.
