coolant expansion tank
Sorry, this is a stupid question but I've done a search and checked my handbook but still can't clarify the answer.
Should the coolant level in the expansion/reserve tank be checked when the engine is hot or cold?
I had my coolant changed yesterday and on checking this am, the expansion tank is just about empty. The coolant is at the correct level in the radiator though.
I would reckon on checking it when cold, when the cooling system is hot it's under pressure and there is a risk of scalding yourself with steam/very hot water.
As for the drop in level it could simply be air in the system migrating up to the expansion tank and therefore causing a drop in fluid level.
HTH
HTH
[QUOTE=Slickline,Jul 27 2007, 10:41 AM] I would reckon on checking it when cold, when the cooling system is hot it's under pressure and there is a risk of scalding yourself with steam/very hot water.
HTH
HTH
rudyy
Apr 26, 2020 02:13 PM
