Vtec Controller
Old Aug 30, 2007 | 08:23 AM
AP100_JA's Avatar
Thumbs up Vtec Controller
I have had my S for a while, got a couple of things into, magnaflow dual exhaust, Test pipe, Spoon ETD, Cusco Cooling plate. But I have always wanted a Vtec Controller. I dont know what to get and where to get it from. To tell you much I kinda dont know what it really does, i know that you can set the vtec higher or lower w.e to your prefence.
What are the goods and bads about having one? What should it be set at? Where do i get one and which brand do i go with? what are the price ranges? Are their controllers that have multi-funtion? And where should i take it to get installed, or can i do it myself?(i can get around mechanics, was an assitant tech for 2 years)
Post them up here. I would really like to get one really soon, preferably by homecoming
thanks,
Anleth
Old Aug 30, 2007 | 08:53 AM
MpBradyS2K's Avatar
I've always heard that it's probably not a good idea to use these. I think it's a really cool concept don't get me wrong, but the car is set to utilize that higher/longer profile when the dynamic conditions are exactly right. This means that there is sufficient air flow into and out of the cylinders. Changing the set point for Vtec means you're engaging at a different rpm and a different (lower) cylinder speed. This could potentially cause loss of power because you just don't have the dynamic properties for the Vtec cam profile.
Just my understanding, maybe someone else can shed some light on this to either verify or suggest something different.
Honda engineers I'm sure have investigated extremely with different Vtec engagement points. The engine has been said to be tuned to it's fullest. Considering this a not a "mod", i.e I/H/E, I can't see it being beneficial in any way.
Old Aug 30, 2007 | 09:02 AM
__redruM's Avatar
Yes, but once you've changed the flow by putting larger exhaust on (headers), then some benifit may be gained from lowering the VTEC engagement point. I'd wait until I had headers before lowering, but a TP might be enough.
Also I think the ECU acts as the VTEC controller, so the OP is really looking to upgrade the ECU. This isn't cheap though and will require a dyno tune.
Old Aug 30, 2007 | 09:33 AM
negcamber's Avatar
There are a few types of controllers
Old Aug 30, 2007 | 09:35 AM
AP100_JA's Avatar
Yes this is what i have heard and it does make sense, because they have tuned it to its fullest.
But also if you do upgrades on like the manifold and headers then it should be consider then ?
Old Aug 30, 2007 | 09:43 AM
plokivos's Avatar
i would imagine there wouldn't be that much worth-a-while gain if you don't have a different cams... like 290's.
Old Sep 4, 2007 | 08:58 AM
AP100_JA's Avatar
Thanks so much for the help you guys!!!
Old Sep 4, 2007 | 09:04 AM
toofast4yalll's Avatar
Thanks negcamber you saved me a lot of typing
doddg
Apr 8, 2014 10:51 PM
dsddcd
Aug 3, 2008 02:15 AM
spotch
Mar 21, 2005 08:18 PM
TunedS2000
Jun 20, 2004 08:48 PM
