FMIC with a S/C
Old Sep 5, 2007 | 07:17 AM
puffyone's Avatar
Default FMIC with a S/C
ive seen some people running a front mount with a s/c. i was wondering what are peoples thoughts on this. better performance. i like the look personally. any thoughts would be appreciated
Old Sep 5, 2007 | 07:29 AM
BondoBuilder's Avatar
I also had the same question. I bet the front mount produces a lot more heat than out aftercooler. Plus, the SC turbine is different...?
Old Sep 5, 2007 | 07:40 AM
Quivers's Avatar
Banned
Just make sure your piping isn't crazy wide or you'll lose substantial boost pressure.
Old Sep 5, 2007 | 08:06 AM
Sideways's Avatar
IMHO, FMIC is a step backward in performance. Centrifical superchargers have a limited amount of boost and anything that decreases boost will decrease the ultimate performance. The aftercoolers marketed by Vortech and Comptech do a great job of lowering intake charge temperature.
Old Sep 5, 2007 | 08:14 AM
73Zero's Avatar
Lots of work for very little (if any) performance gain.
Old Sep 5, 2007 | 10:03 AM
puffyone's Avatar
but the vortech system for the z uses a front mount. i get what your saying also. but like if you up'ed the boost and had the front mount, wouldnt you be fine?
Old Sep 5, 2007 | 10:16 AM
WashabiS2K's Avatar
there are a few people out there that did have the FMIC setup with a centrifugal supercharger and they said they lost barely any boost tho if there was ever a FMIC setup for my comptech unit that did not lower boost and made a difference in cooling (in a good way) ide be all over it.
Old Sep 5, 2007 | 10:22 AM
puffyone's Avatar
what i dont get tho is basically the same S/C that vortech makes for the Z comes with a fmic
Old Sep 5, 2007 | 05:14 PM
EriS2k's Avatar
I have a FMIC Setup on my S2k, Running a 12psi Pulley and my Greedy Boost Gauge Reads 12psi, My Piping is 3' diameter!
No Performance loss Here
Old Sep 6, 2007 | 03:59 AM
puffyone's Avatar
yeh i member talking to you about it and you said you didnt have any loss... i was just seeing what other people thought
