Sponsored by:
Sponsored by: CARiD
Racelogic Owners Thread
Old Dec 10, 2007 | 10:48 AM
CKit's Avatar
Default Racelogic Owners Thread
Got a few PMs from people purchasing the unit. Thought I'd get around to posting an install DIY. Couldn't find my digicam, so will have to settle for crappy cell phone pix.
--CKit
"Scotchlok" T-taps. Put one wire through and one unstripped wire alongside.
Clamp the metal bridge down and lock the cover over and the wires are spliced together. Solder if you'd like for more stability. Cover with electrical tape.
You can tap into the ACC fuse or into the ACC power wire (green wire in diagram is tapped to power).
The ECU has three wiring harnesses. Front to back are "A," "B," and "C."
"A" has the blue #19 wire for the tach. "B" has the injector cut wires. You don't need to tap into the "C" harness. Refer to the wiring diagrams posted above for the coloring of the wires to splice into.
For the ABS wires, it doesn't matter which color wire goes to what ABS sensor.
Old Dec 10, 2007 | 12:00 PM
NVMY4N's Avatar
PM me when this is complete.
Old Dec 10, 2007 | 08:31 PM
shinigamiz's Avatar
i've already told you through PM, but i figured i will put it here as well. i have every intention of trying to do this install this week/end. thanks again for doing this!
Old Dec 10, 2007 | 10:49 PM
NVMY4N's Avatar
If you guys don't mind, please snap pics, and make a few notes.....or a bunch of notes
Thanks
Brad
Old Dec 11, 2007 | 04:29 PM
asng's Avatar
post pix. lots of them. i wanna see how you cut into the abs wires
Old Dec 11, 2007 | 08:13 PM
squirrels2k's Avatar
i too am very interrested in a diy
Old Dec 11, 2007 | 10:47 PM
CKit's Avatar
Some pictures posted. The ECU wires aren't labeled in the pictures yet.
Also have to get a picture of the ACC power and grounds.
But it should be a place to start.
Old Dec 14, 2007 | 01:54 PM
CKit's Avatar
PM with questions.
Old Dec 14, 2007 | 03:52 PM
shinigamiz's Avatar
very nice! i just printed the page so i could refer to your pictures.
an additional note, here are the pages for the wiring diagrams (from service manual for 2000-2006)
Connector A: 11-17
Connector B: 11-19
ABS: 19-37
Old Dec 14, 2007 | 05:30 PM
TestaRossa's Avatar
excellent write-up
