cam gears
Old Jan 5, 2008 | 08:27 AM
Jpea_s2k's Avatar
Default cam gears
i was wondering if i should get some cam gears. if yes, what brand should i get? and what do they do?
Old Jan 5, 2008 | 10:31 AM
mxt_77's Avatar
If you don't have aftermarket camshafts, I wouldn't bother.
AFAIK, Toda is the only company making cam gears for the S2000. The design isn't as simple as the gears/pulleys on the old Integras/Civics.
Basically, adjustable cam gears are used to fine-tune the camshaft timing so you can advance or retard the cams in relation to the piston stroke and in relation to each other. Sometimes this can be used to get more power, but from most of my research, it seems like it's generally used just to move the peak power/torque to a different part of the powerband.
These are not plug & play items. If you buy these, expect to invest a considerable amount of money on dyno time & tuning with an experienced tuner.
So, in summary: Don't bother.
rednikos
Oct 6, 2009 11:13 PM
midnightsunset
Feb 22, 2009 03:09 PM
qbmurderer13
Feb 7, 2009 02:30 PM
REVZ TO9
May 9, 2007 10:24 AM
Roll_On_S2K
Apr 24, 2007 04:18 PM
