Wheel balancing
Old Jan 21, 2001 | 09:49 PM
Dorian Gray's Avatar
I just noticed a fairly large screw in my rt rear stock tire. I'm going to take it to Discount Tire tomorrow. I have a few questions that I could use some help with.
1. Is there any way in particular that the car should be jacked up?
2. After the tire is patched, how should I have them balance it?. ie. where to tell them to put the balancing weights.
3. What should the torque wrench be set at when tightening the bolts?
Thanks
George
Old Jan 21, 2001 | 11:12 PM
Schatten's Avatar
1- they will tyipcally use the bay lifts, so dont worry, but if they don't and just jack up the car, see this page: https://www.s2ki.com/faqs/faq_jack.php
2 - they will see where the weight came off, mark it - thing is, this is the important part - they typically do not rebalance the wheels on repairs - you need to make sure they do! the balance of the tire IS changed when you put on a patch and the tire doesn't go on 'exactly' like it was before. Make sure they re-spin it on the balancer and use an aluminum stick-on weight on the inside of the wheel.
3 - they will take care of that, not to worry - either by their torque sticks or by their torque wrenches.
p.s. - make sure you get a patch, not just a plug. it only takes a few minutes extra to do the patch and both require removing the tire from the wheel.
VilleS2K
Aug 27, 2012 09:42 AM
physic
Aug 4, 2010 08:45 AM
kent-k
Mar 2, 2006 03:25 PM
kjgood
Sep 20, 2004 05:20 PM
Partshelper
May 17, 2003 07:17 PM
