HELP ASAP - MY02 Hardtop Question
Old Apr 16, 2002 | 04:23 AM
Triple-H's Avatar
Default HELP ASAP - MY02 Hardtop Question
These questions apply to 2002 cars that HAVE HAD the hardtop installation done.
Where is the defrost switch go for the rear window in the hardtop?
Does this hardtop rear window use the same defrost switch that is in the dash of the 2002 or do they install a second switch in the center console to be used for only the hardtop?
Another Question - have you ever heard of the door panels needing to be removed so the electric windows can be adjusted to make the hardtop fit properly?
I was supposed to pick up my '02 Spa last night, but once I got there I could see clearly they were working without a clue.
Thanks!!!
Old Apr 16, 2002 | 06:09 AM
Triple-H's Avatar
Help!!!
Old Apr 16, 2002 | 06:18 AM
JonasM's Avatar
1. Yes, you use the same switch. Only earlier models get a second switch.
2. I don't know.
You can download a PDF file with the 2002 installation instructions from HandAAccessories. I looked in my copy, and here's a quote from Page 10 on adjustments to the fit:
'If window glass adjustment is required, refer to the service manual'
Obviously, Honda anticipates that adjustments may be needed to the glass in some cases. My tech didn't say anything about it, so I don't know either way if mine needed it.
Relax - you're almost there!
JonasM
Old Apr 16, 2002 | 06:19 AM
JonasM's Avatar
P.S. - The PDF File isn't 100% accurate - it still lists the extra defroster switch, which may be a source of some of the confusion.
JonasM
Old Apr 16, 2002 | 06:21 AM
Triple-H's Avatar
JonasM, You are my hero today!!!
Everybody agee???
Old Apr 16, 2002 | 06:32 AM
Triple-H's Avatar
OK- I'm so confused!!!
The 2002 instructions for the hardtop as a download from H and A says the rear defrost switch IS IN the center console for a 2002.
Old Apr 16, 2002 | 06:45 AM
JonasM's Avatar
That's what I mean by not 100% accurate.
I don't know if the techs have access to better instructions. I would hope so.....
Worst case, I could try to get in touch with the tech who did my install to see what he did.
JonasM
Old Apr 16, 2002 | 07:40 AM
Triple-H's Avatar
I'm calling Honda now, I'll keep you posted...
Old Apr 16, 2002 | 08:17 AM
Triple-H's Avatar
Problem solved!
My dealer was using Publications No. All 23256, Issue Date OCT 2001.
They should have been using Publications No. 23256-23531, Issue Date MAR 2002.
The defrost switch DOES NOT go in the center console on a 2002 model.
Once again, Thanks S2KI, you are the best.
Now I can get my car tonight!
S2K2GO!!
Nov 14, 2010 04:44 PM
former_ep3
San Diego S2000 Owners
Oct 15, 2008 10:36 PM
CTR_2_SIIK
Apr 29, 2006 06:55 AM
Spaceman Spiff
Aug 24, 2005 08:38 AM
JohnS2K
Nov 20, 2002 07:08 AM
