Which spark plugs to buy?
Old Aug 16, 2008 | 11:50 PM
DBXFX's Avatar
Default Which spark plugs to buy?
I've seen all these threads about spark plugs failing and what not, so i wanted to post and see what the most recent discovery is for the best spark plug.
My car is NA but might go FI in a year.
I want long lasting plugs = less maintenance.
So which plugs should i buy, how much are they, when do they need to be replaced, what should i torque them to (what if i dont have the adapter?), and what should the gap be?
thanks
Old Aug 17, 2008 | 12:19 AM
blkwidow's Avatar
OEM...Search
Old Aug 17, 2008 | 01:02 AM
Psilos's Avatar
I have NGK Iridium IX, IFR7G-11KS. I have them for 6000kms, no problem so far, very smooth idle.
I used a torque wrench set to 18 lbs/ft and a 16mm spark plug socket. Gap is pre-set from NGK as these spark plugs are for S2000
Old Aug 17, 2008 | 02:07 AM
energetic's Avatar
Whatever you do, DO NOT get DENSO!
Old Aug 17, 2008 | 02:58 AM
damuho's Avatar
What is wrong with Denso spark plugs? I'm curious: Have you used them and got bad results?
My stock AP2 came with the OEM Denso PK22PR-L11S platinum plugs which worked very well so when I wanted to try iridium, I stuck with Denso. I read about the electrodes falling off on rare occasions but I think they are due to damage from gapping. The model I got is the IK22G with the 0.4mm electrode so I was very careful when I regapped them to 0.043" (they came in gapped at 0.032"). I got the IK22Gs for $10 a piece.
So far, they have worked just as well as the original Denso platinums.
Old Aug 17, 2008 | 03:18 AM
energetic's Avatar
I heard and read on S2KI up to now, many engine breakdowns due to the DENSO plugs (electrodes falling is not rare). This is a good reason for me to discourage the community to use them.
NGK FTW, as Honda uses them as well!
Old Aug 17, 2008 | 06:45 AM
ctb2024's Avatar
i have used ngk plugs as well and i'm FI since november last year...only changed them once just to see if there was a difference with the weather and tune--plugs worked the same, great as always.
Old Aug 17, 2008 | 10:01 AM
qbmurderer13's Avatar
Stick with OEM.
Old Aug 17, 2008 | 11:03 AM
Bob A (SD)'s Avatar
I just bought a set of NGK BKR7EIX-11 (#6988) iridium plugs. This after looking carefully at the NGK lineup. I could either have stayed with the OEM platinums but wanted to go with iridiums. These are the same heat range, gap, et cetera et all as the stock plugs.
Old Aug 17, 2008 | 11:17 AM
shotiable's Avatar
oem. i heard sparks dont do anything performance wise and the oem is best for the s2000
