Passenger window won't roll up!!! What da Hell
Old May 18, 2002 | 08:49 PM
Gernby's Avatar
Default Passenger window won't roll up!!! What da Hell
I know that there are a lot of problems with the auto down function on the driver window, but have any of you had problems with the passenger window? I just put my top up, and the window rolled down, and now I can't get it to go back up. It is dark outside, and I don't have my owner's manual, so I haven't tried checking the fuses, but the driver side works fine.
Old May 18, 2002 | 08:50 PM
Ludedude's Avatar
Administrator
Check the lockout switch on the drivers side.
Old May 18, 2002 | 09:16 PM
darkknight1999's Avatar
You have to unlock the passenger side window on the drivers door
Old May 19, 2002 | 08:48 AM
Gernby's Avatar
Now that is pretty stupid! I didn't think of that, simply because I figured it should still work from the driver's side. Why would the switch disable the driver's ability to roll up the passenger window?!
Thanks.
Old May 20, 2002 | 05:46 AM
dhess's Avatar
Ive been trying to figure that one out for ages!
Its got to be one of the biggest design **** ups of all time!
Old May 20, 2002 | 06:44 AM
Gernby's Avatar
[QUOTE]Originally posted by dhess
[B]
Old May 20, 2002 | 07:39 AM
GSRacer's Avatar
hahahah same thing happened to me this weekend. i was so pissed off, until i realized i had the power switch on the off position .
Old May 21, 2002 | 12:00 AM
dhess's Avatar
I think Honda's Power Window Design Engineer needs to be terminated.
I agree. He/She is a candidate for retrospective abortion.
Old May 21, 2002 | 09:44 AM
infinitebass's Avatar
Banned
[QUOTE]Originally posted by gernby
[B]What seems like more of a screw up to me is that every time you put the top up or down, the windows go down, and the driver has to put them back up.
Old May 21, 2002 | 10:24 AM
Gernby's Avatar
Originally posted by infinitebass
There is quite a bit of pressure exerted directly on the glass when the windows are up and the top is up to form a water-tight seal. So, the windows need to be rolled down in order to put the top up so the extra force of the top hitting them along with the pressure doesn't cause problems by slightly forcing the motor to reverse or breaking the glass itself. I don't know how likely you'd have problems, but why risk it?
Also, most people leave the windows down for at least a few minutes after putting the top down, so you'd be putting the windows down more often than you put them back up currently.
So actually, it is a MUCH better design than most people would give credit for.
And if you're putting the top down, you should have the windows down anyways unless doing over 60 mph, when it actually helps quiet the wind noise. I know I'm not the only one who thinks cars loook retarded with the top down and windows up.
Now one thing I am willing to bitch about is the window lock and not having a god damned button to unlock BOTH doors on the driver side. I HATE reaching over to yank on the incredibly poorly placed and sized latch on the passenger side.
Blake
My brother had a BMW 325 convertible that would just roll the windows down a couple inches when putting the top up. Once the top was up, it would roll the windows back up again. If the windows were down when you put the top up, it would roll them up after the top was up. I think it would only roll the windows completely down if you continued holding the button after the top was down.
