How do you hook up the optional Greddy A/F harness
Old Sep 22, 2008 | 08:55 AM
RichV's Avatar
Default How do you hook up the optional Greddy A/F harness
I have a Greddy turbo kit and AEM Uego and bought the optional A/F ratio harness so I could monitor the A/F ratios in the emanage. Does anyone know what wire goes where. I plugged the harness into "option 1" on the emanage and it has a blue and white wire coming out of it (I think those are the colors). The Uego also has a blue and white wire coming from one of its harnesses for monitoring purposes. I think I remember reading it wasn't simply color to color. Does anyone know how to hook these up? Thanks guys!
Old Sep 22, 2008 | 11:52 AM
dsddcd's Avatar
Greddy Harness to UEGO:
White to White
Grey to Ground (make sure this is the same grounding point of the UGEO)
Use Neko 10-20
Old Sep 22, 2008 | 12:27 PM
RichV's Avatar
So I don't hook up the blue wire on the UEGO at all?
By the way, thanks for the response dsddcd
Old Sep 22, 2008 | 01:21 PM
dsddcd's Avatar
No, the Blue wire is serial output wich would be hoked up using a 3.5mm jack to the serial port if you wanted t use that port.
No problem i asked this a while back and never got an answer and had to do some research on www.emanageforums.com to find it. The emanage is a big mystery and the people that understand it want to keep it that way.
Old Sep 22, 2008 | 02:21 PM
JoeyBalls's Avatar
Wait, so nothing is tapping into the Downpipe? its all read from the ECU?
Old Sep 22, 2008 | 03:57 PM
dsddcd's Avatar
Nope, you still need the wide band in the exhaust, this is just to hook the wide band to the Emanage for data logging and the auto tune feature.
Old Sep 23, 2008 | 06:31 AM
RichV's Avatar
Thanks again ds, I got it hooked up last night. Was easy enough.
Joey, you still need to get a new bung welded in the downpipe for a wideband. I'm glad I did it before I even started my install. I wouldn't want to take it off after I installed it, but the wideband has been useful to me.
Old Sep 23, 2008 | 06:36 PM
revhi's Avatar
I have a emanage blue and uego. I hooked up white to white and grey to ground. What do I do in the parameter settings? I cant seem to get anything to save if I change the one drop down from "disconnect" to "a/f". Also I cant seem to expand the parameter screen more than this. I know there is vtec and other check boxes lower down on the screen that cant be seen.
Old Sep 24, 2008 | 10:38 AM
dsddcd's Avatar
[QUOTE=revhi,Sep 23 2008, 06:36 PM] I have a emanage blue and uego.
Old Aug 6, 2010 | 12:29 PM
jonnys2k01's Avatar
can some one tell me when i connect white to white and grey to same ground as aem car wont run??? theres only one white on the harness and theres two white on the gauge.. i used the white coming from the aem 02 sensor
