Greddy Turbo Kit AP2 Dyno Results
Tuned by Jason from Portland Speed Industries (psi) in Oregon. Here are my results from today dyno pulls.
Mods:
Greddy AP2 Turbo Kit
Invidia V4 Dual Exhaust
Berk TP
10psi boost
Mods:
Berk TP
10psi boost
Wow! 327!! I am at 274 witht the stock exhaust but I want the V4 and will probably get it early next year. Couple questions for you... What A/F ratio are you running. At WOT what does the ratio start at and rise to. Mine starts at 10 and rises to about 12.5 at 7K. Also, what boost controller and spark plugs are you running? Lastly, does your boost hold at 10 from the time it reaches full boost to redline? Mine seems to be dropping off to about 7.5 psi. Trying to see if that is normal... Thanks, and very impressive numbers!!
Do you have a plot with boost and the A/F? Something is odd with that dyno. The Greddy kits ive seen have torque peak around 5.5k then start falling off. Yours seems to climb all the way to redline which usually indicates boost creep.
