tire size for 18" wheels
A definitive answer to the following question would be nice, but an educated guess would be OK too.
I am getting 18" wheels; as noted in s2ki FAQ, tire sizes should be 225/40 in front, 255/35 in rear. However, the tires I want to get (s-02 PP) only come in 225/35 for the front.
The potential issue I see for this size is the difference in diameter between the 18 and the stock 16 front (diameter for rear 18 and 16 stock are almost the same). The 225/35 dia is 24.2; stock front dia is 24.9 - over 1/2 inch difference!
Also, rpm for 18 varies a fair amount from stock 16. Do odo and speedo come off front tires? If so, seems like there would be errors in speed & mileage. Also, wouldn't the front of the car be slightly lower than the rear?
How about asthetics? Not all mods are for speed and performance... I am adding 18" Workmeisters because they are gorgeous. If the person wants to individualize his car, let him!
I have ~ $25,000 in mods in my car, about 1/3 - 3/8 of it are for speed/performance the rest is just for fun.
A lot of people buy cars to modify/personalize them as a hobby. I bought the car solely for hobby/modifying myself.
Just defending the guy...
Back to the discussion: the speed comes off the transmission in the form of the VSS (vehicle speed sensor) connector... So the rear wheels would be those that affect the speed. My recommendation: keep the wheel circumferance as close to stock as possible. I'm going 225/40 18 in front and 265/35 18 in back (not taking my own advice in the rear
). A really cool tire size calculator that someone posted here before:
http://www.miata.net/garage/tirecalc.html
It's posted by a Miata site but tires/wheels are tires/wheels...
). A really cool tire size calculator that someone posted here before:http://www.miata.net/garage/tirecalc.html
thank you shaner:
you're worse than I am - I'm only getting $14K in mods (including the comptech SC)
maybe I'm a fool with more money (or at least credit) than sense, but this is something I want to do. At least I want to understand exactly what I am doing and what the potential ramifications are. And personally, I don't particularly like how the stock wheels look. And I like the look of big, fat meats on a car.
I know the ideal front size for the rims I am getting is 224/40, but I can't seem to find a well rated tire that has both 225/40 and 255/35 sizes. That's why I want to know if it is a bad thing to put 225/35 on the front.
I'm VERY new to tire/wheel talk...so correct anything I say that is wrong. I'm assuming that the most important thing is that your tires/wheels give the lowest difference in speedometer readouts, and that the stock vs. after market set up has roughly the same #'s in regards to Radius, Diameter, Circumfrence, and Rev/mile.
If my assumption is correct, with that Tire Calculator...I see that the closest to stock #'s given come from the following tire sizes:
Front: 215/40/18
Rear: 245/35/18
Keep in mind stock sizes of 205/55/16 for Front and 225/50/16 for the Rears.
Again, I'm TOTALLY new at this...so excuse any of my ignorance. But after playing with that calculator for a while, I find that the closest to stock figures comes from these sizes. If you find something better...please do tell!!
Front: 215/40/18
Rear: 245/35/18
Besides the sizes, I really hated the PP's they really hampered the cars handling, it got better with wear but when I put on the new ones. OMG it may be a tick better than stock! My latest set of tires is the Bridgestone RE-730
the 245/45 r16's are actually about a half inch wider than stock SO-2's (rear)
Tirerack has good spec charts for most tires so you can compare overall diameter and tread width. I think its suggested that you dont have more than .10" difference in OD because of the ABS.
the 245/45 r16's are actually about a half inch wider than stock SO-2's (rear)...
...Tirerack has good spec charts for most tires so you can compare overall diameter and tread width.
