Mark this thread as Sold
FS: Lots of OEM parts + kw v3's
Old Dec 1, 2008 | 10:27 AM
SC_Highlander's Avatar
Default FS: Lots of OEM parts + kw v3's
I need to clear out my garage. Please add paypal (3%) and shipping to all prices if necessary. Everything is first-come-first-serve. No 'dibs'.
My original blue seats. I had the foam in the seat bottoms replaced by an upholstry shop after I took them out of the car, so it's brand new. Asking $400 OBO SOLD
Slightly used OEM clutch friction disc. Asking $50.
center glovebox. Asking $50
trim panels behind doors. Asking $15 for both
rear tray. Asking $10
passenger side kick panel. Asking $10
driver side kick panel and passenger side AC vent Asking $10 each
MY2000 catalytic converter. Needs exhaust studs replaced. Asking $50 SOLD
MY2002 instrument cluster surround w/ audio control and hvac controls. missing start button and defroster switch. Asking $80
MY2000 emissions air injection pump with tubing and relay. Asking $125
MY2000 battery heatshield heatshield sold, cruise control module, stock intake tube. $10 each
MY2000 air injection solenoid (on back of intake manifold) $10
MY2002 ignition coil packs $125 for the set of 4.
MY2000 center console. the spring in the cupholder is broken. Asking $50
AC hardline $5 (left)
MY2002 alternator (top, right) $75
MY2005 AC compressor w/hoses (bottom left) $75
MY2000 AC compressor (bottom center) $50
vacuum manifold/hoses/solenoid (bottom right) $5
freshly rebuilt front calipers and brackets (center) $100 Calipers no longer for sale
black AP1v1 door panels. unassembled. $85 OBO for all 4 pieces
blue MY2002 door panels. complete except for the window switches. The plastic panel corners have minor damage. $75 OBO for the pair of panels
a pair of AP2v1 front wheels. cosmetic blemishes. one took some extra weight to balance. Good for track wheels or as paint/powder candidates. $100 for the pair.
3 complete sets of AP1 wheels. All have cosmetic blemishes. All are suitable for track wheels or refinishing. One set has usable rear Fuzion ZRi's and dead fronts. One set has a set of dead Kumho v710's. One set is spray painted black and has a set of dead Kumho MX's mounted. $200 per set of 4, or $500 for ALL OF THEM!
AP1 flywheel, 120k-ish miles. $50.
KW v3 coilovers. Approx 25k miles of use. Includes stock tophats. Ready to bolt in. $1200 OBO SOLD
NOT PICTURED:
AP2 flywheel 23k miles $30.
MY2002 starter (88k miles). $100
MY2000 stock coilovers (springs,shocks,tophats). 99k miles $100
MY2002 stock shocks only. 65k miles. $75
Harbor Frieght 4ft trailer. Complete with plastic front toolbox and PVC tire holders on back. 12in tires. Asking $200
MY2002 motor. Details: This motor was starved of oil in April 2007, which resulted in damage to most of the main and rod bearings. I pulled the motor and replaced all the bearings, took the head to Dover Cylinder Heads for replacement of all the valve retainers and keepers. They gave the valves and all other head parts a clean bill of health. I also had them polish the crankshaft as well. During the rebuild, I replaced the oil pump, all oil seals, all gaskets and the thermostat. After the motor was reassembled and installed in the car, it ran fine for about 6k miles before it started randomly pulsing at idle like it was misfiring. No misfire sounds could be heard, and it never threw any diagnostic codes. I could also hear a very low volume knock. Rather than deal with pulling and rebuilding again, I dropped a junkyard motor in my car. My suspicion is that the oil starvation incident damaged the crankshaft, but I have not confirmed that. The motor made normal power (buttdyno) and had good oil pressure when pulled. I have not taken it apart yet. As it sits, it is missing the coilpacks, alternator, AC compressor, clutch, flywheel, and starter. It has an F22c sparkplug cover. Asking $1500 as is with no guarantees. Should be a good candidate for a stroker or FI build, as the cylinder walls, rods and pistons all looked good during the rebuild.
During the rebuild (Dec 2007)
Items sold:
OEM Honda hardtop stand. $150 -- SOLD to YELLOW JACKET; delivered
Spoon N1 single exhaust. Asking $350. SOLD to Genius; picked up in person
MY2002 OEM header -- SOLD to 518135; shipped
AxialFlow Short Shifter -- SOLD to airgate
Old Dec 1, 2008 | 10:36 AM
iLuveketchup's Avatar
Willing to ship the roll bar?
Old Dec 1, 2008 | 11:51 AM
S2000 Type_S's Avatar
Bryan u have a pm!
Old Dec 1, 2008 | 12:32 PM
pyro40t's Avatar
can you get my a pic of one of the sets of ap1 wheels so i can see the "faces"
Old Dec 1, 2008 | 12:53 PM
Sure. I'll do that tonight.
Old Dec 1, 2008 | 01:20 PM
spitvenom's Avatar
I removed all the rear plastics including the roll hoop covers can you Pm me all the plastics you have please.
Old Dec 1, 2008 | 03:07 PM
Here are the two fronts from the worst set:
Old Dec 1, 2008 | 03:08 PM
I have all of the plastic panels except the driver's side roll hoop.
Old Dec 1, 2008 | 04:31 PM
pyro40t's Avatar
How much shipped to 08753 for a set of the ap1 wheels front and rear Ill even take the dead tire set as I plan on making them my winter wheels
Old Dec 2, 2008 | 03:57 AM
PM'ed
