:::disclaimer- I am not responsible for anything you do after reading this.:::
Since I have owned the car, it has had the annoying and very aggressive "shakes" on acceleration through all gears. soooo, I spent Wednesday night swapping the inner cv's from left to right. I also bought some halfshaft spacers to prevent long term damage to the driveshaft since the car is lowered.. I don't know how much the spacers will help, but I figured I could put them on when I do the swap to push the CV back in. ::edited:: Here are the pics.
my "office"
You can borrow this tie rod end puller from your local auto parts store.. i went to autozone.
:Notice: the left (driver side) CV grease is darker due to metal shavings in the grease. booo.
Well there's your problem... The freakin Grand Canyon in my CV joint. (driver side) on all three columns.
Here are the installed 10mm spacers.
I have gotten all the information I needed to do this job from the s2ki forums here, thanks everyone!
After my test drive... The car has NEVER driven as smoothly as it does now! I can actually feel the RPM's insted of the freakin "shakes".
Since I have owned the car, it has had the annoying and very aggressive "shakes" on acceleration through all gears. soooo, I spent Wednesday night swapping the inner cv's from left to right. I also bought some halfshaft spacers to prevent long term damage to the driveshaft since the car is lowered.. I don't know how much the spacers will help, but I figured I could put them on when I do the swap to push the CV back in. note: This is not necessary on AP2's. Here are the pics.
my "office"
nice pictures. your pit is literally 10 times worse than mine. your vibrations must have been really rocky.
can you explain how spacers prevent long-term damage to the driveshaft (or any damage for that matter)? I believe spacers only change the contact area of the roller balls in the cv joint.
can you also explain why this is not necessary on ap2's? I do not think the ap2's are immune to cv joint pitting.
From what I've read the "fix" for the shakes was in 04 so only cars with miles on them were starting to get the shakes. AP2s are just as capable of getting them as the AP1.
yea, it was terrible. Aggressive shaking at any speed above 30mph.. specially highway driving, it was nearly unbearable. I couldnt be happier right now!
I was lucky to not have any pits but I decided to rebuild the cv's just for the heck of it. I even went as far as taking apart all of the 6 roller bearings and completely randomizing the tiny rollers and repacking them. The Redline CV-2 grease works great! by the way if you swap the cups you don't need the spacers since you are creating new wear spot already.
