Sponsored by:
Sponsored by: CARiD
Ti Lugs
Old Jan 28, 2009 | 04:35 PM
TookayS2K's Avatar
Default Ti Lugs
They look just like Muteki's Neo lugs except for a few minor differences.
I talked to the seller, he said they are pretty much exactly the same. Also, that they are from the same manufacturer (he said seibon.. ?? i didnt know they were the same co.)
Anyway, anybody have any more info on "Ti" lug nuts
Old Jan 28, 2009 | 05:11 PM
slaberdy's Avatar
those are garbage. kics wannabes but they are similar grade to zenki lugs im guessing
Old Jan 28, 2009 | 07:14 PM
TookayS2K's Avatar
Have these failed on you before? What exactly makes them garbage? So muteki is garbage as well?
Old Jan 28, 2009 | 09:31 PM
WashabiS2K's Avatar
they aren't Ti.. they are just regular lug nuts with some fancy paint on them.. once they are mounted, the finish begins to chip.. but if you hardly ever remove the lug nuts, i guess they are ok. Atleast the Kics Project Neo Chrono's finish does not chip
Old Jan 28, 2009 | 11:02 PM
NightRider's Avatar
Your wheel paint/coat will chip before the Neo-Chros do
Old Jan 29, 2009 | 12:16 AM
TookayS2K's Avatar
I know they are not titanium. "Ti" is the BRAND of these lugs.
I just want to know how these compare to MUTEKI. Obviously, these can't compare to Kics.
Here are some actual Muteki lugs:
Again, I'm trying to compare these to MUTEKI. The seller says they are the same thing and from the same manufacturer. I just need to confirm that his story is legit.
Thanks.
Old Jan 29, 2009 | 05:15 AM
Dressed2Kill's Avatar
That is a yellow/rainbow mix zinc plating on them. Yes it will wear/scratch off over time.
Old Jan 31, 2009 | 02:44 PM
HondaGal's Avatar
So does anyone have any good information for this question
Old Jan 31, 2009 | 03:21 PM
TookayS2K's Avatar
Thanks.
I spoke to the seller again and asked him to be a bit more clearer. He told me again that Muteki and TI are both made from the same manufacture in Taiwan. However, TI is branded by Seibon. I tried googling this nothing came up in my searches.
I wouldn't mind getting them if I can confirm if they are from the same manufacture because the Muteki Neo's do not chip and fade. (as I've read from many different forums)
Old Jan 31, 2009 | 03:26 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Mackins...
