rear right wheel noise\ rear end noise?
Old Apr 13, 2009 | 06:28 PM
David2000S2000's Avatar
Default rear right wheel noise\ rear end noise?
recently i changed the tires on in the back only and once i drive perticularly on the high way for a good 10 min i hear a noise that becomes more appearent the slower i go, like its in intervoles the slower i go the longer the time frame the faster i go the faster the time frame. so its something thats rubbing maybe, the noise sounds like rubbing unlubed metal or kinda like brand new tires when your rolling them around a smooth dry surface. i also notice that the rim had a deep gash at two points and when i jacked it up it didnt spin true but its not that dramatic.
does anyone know what it sounds like when you need new bearings in the rear end?
or do you guys think it might just be the tire after it warms up and since the rim is not true it making that noise?
i bought a new rim thats like new and true and its on it way and im hoping that solves it.
but i really need any opions, i dont know too much on s2000
Old Apr 13, 2009 | 06:58 PM
negcamber's Avatar
Does it make the noise when you apply the brakes?
Old Apr 13, 2009 | 07:12 PM
no not all and i put it in nutual and let it coast and still hear the noise, but only after maybe ten or fifteen min of driving
Old Apr 13, 2009 | 07:16 PM
SgtB's Avatar
Sounds like the bearings. Jack that wheel up and try shaking the wheel. I had a loose hub nut on mine. A 1/8 turn fixed it.
Old Apr 14, 2009 | 09:43 AM
my2ks2k's Avatar
read through a couple of threads on noise from the rear/wheel bearing noise...
https://www.s2ki.com/forums/index.php?showt...&#entry15834201
https://www.s2ki.com/forums/index.php?showt...&#entry15796095
https://www.s2ki.com/forums/index.php?showt...&#entry15438011
welcome to the site and good luck let us know if we can help
Old Apr 14, 2009 | 03:19 PM
wow yes these are alot of help its the same problems,
thanks for the imput i needed it
Old Jul 10, 2009 | 08:15 AM
projektflux's Avatar
affected area: rear right wheel
done the axle nut tightening
I am having similar issues, my problem begins after 15miles of hwy driving, city driving no problems. It started with a loud squeek, and now its a loud squeek with some minimal vibrations.
It squeeks at each rotation of the wheel. The car can be parked (turned off, with the hand brake on or off) i can rock the car back and forth or rock the tire in and out and the squeek is there.
I have taken it to a honda repair shop but they could not find anything wrong.
i read all through the forums and would like some suggestions.
new bearings? new bearings and axle?
want to get things correct asap, this is my daily driver.
75 miles per day driving.
symptons for 4 days now.
s2k_Nut
Jul 1, 2010 04:57 AM
thats_mr_2_u
May 16, 2007 09:47 AM
rikhemi
Apr 25, 2007 08:31 AM
KAY'S
Aug 29, 2005 03:38 PM
Pstar
Feb 25, 2005 09:26 AM
