HKS Spring Install help!!!!
Old Jul 4, 2002 | 11:48 AM
VTEC Racer's Avatar
Default HKS Spring Install help!!!!
Hello all!
Happy 4th of July!
Anyways... I'm installing my HKS springs as we speak. My question is, what are those two yellowish/tanish kinda rubber things that came in the box for? It only came with two. Do I need them cause I"m almost done with the front and didnt use them, and am starting the back. And also, I did it for one side, but can't do it on the other side, how the hell do I align the damper and the lower a-arm so that the 17mm bolt will pass through the other end??!!!??!!?? Thank in advance.
And can someone give me instructions on how to load the suspension? Do I tighten the bolts while the suspension has load on it?
Old Jul 5, 2002 | 07:39 AM
sprintr6's Avatar
The bushings you are speaking of are shorter bump stops HKS provides so you don't have to cut your originals.
The rear is kind of a bitch to do. I had to have two of my friends actually stand on each rear hub to put pressure on the rear stabilizer so I could get the bolt through.
Let me know if you have any questions.
Thanks,
Brandon
MMisencik157
Mar 12, 2015 02:57 AM
owenxguo
Sep 20, 2011 10:59 AM
ertbll
Aug 21, 2010 12:48 PM
nrgizeman
Jul 14, 2006 01:18 PM
dave22
Jul 9, 2002 05:33 PM
