DOES S2000 HAVE i-VTEC OR VTEC?
Old Jun 13, 2009 | 10:46 PM
03_BB_S2K's Avatar
Default DOES S2000 HAVE i-VTEC OR VTEC?
I had an RSX which i know was i-vtec but what about the S2000? Is it just regular vtech or the intelligent vtec? Sorry for the dumb question but i was just curious to know
Old Jun 13, 2009 | 10:57 PM
shotiable's Avatar
vtec for the s2000.
i-vtec is evil
Old Jun 13, 2009 | 11:24 PM
ans2k's Avatar
not sure how i-vtec works, but s2k has VTEC! and its goes like vrooooooo.VROOOOOOOOOOOOOOOOOOOOMMMMMMMMMMM!!!!
Old Jun 13, 2009 | 11:37 PM
liquid_helix136's Avatar
Old Jun 14, 2009 | 01:11 AM
dn7309's Avatar
i-vtec is vtec, except the power delivery is smoother in the i-vtec so you dont really feel
Old Jun 14, 2009 | 01:12 AM
plutonium239's Avatar
I think i-vtec varies its crossover point depending on load, rpm etc. where as regular vtec switches over at a set rpm. I have driven just about every i-vtec equipped car and they are smooth but not nearly as fun to run up into vtec as the S.
Old Jun 14, 2009 | 01:16 AM
dn7309's Avatar
that's actually is a misnomer.
I-VTEC is the same as VTEC, though there is an economy version (honda CRV, ACCORD and CIVIC Si EP) and the performance (RSX-S, FG civic Si and Type-R)
Old Jun 14, 2009 | 02:47 AM
ahrmike's Avatar
ivtec is not a continuously variable version of Vtec? (wow, lots of V's)
or am I thinking of the toyota VVT-i
Old Jun 14, 2009 | 07:58 AM
humara's Avatar
wouldn't this have been so much easier?
http://en.wikipedia.org/wiki/VTEC#i-VTEC
i-VTEC (intelligent-VTEC)[4] introduced continuously variable camshaft phasing on the intake cam of DOHC VTEC engines. The technology first appeared on Honda's K-series four cylinder engine family in 2001 (2002 in the U.S.). In the United States, Honda first debut the technology on the 2002 Honda Civic Si EP3 with the economy version.
Valve lift and duration are still limited to distinct low- and high-RPM profiles, but the intake camshaft is now capable of advancing between 25 and 50 degrees (depending upon engine configuratio2n) during operation. Phase changes are implemented by a computer controlled, oil driven adjustable cam gear. Phasing is determined by a combination of engine load and rpm, ranging from fully retarded at idle to somewhat intelligent at full throttle and low rpm. The effect is further optimization of torque output, especially at low and midrange RPM.
The K-Series motors have two different types of i-VTEC systems implemented. The first is for the performance motors like in the RSX Type S or the TSX and the other is for economy motors found in the CR-V or Accord. The performance i-VTEC system is basically the same as the DOHC VTEC system of the B16A's, both intake and exhaust have 3 cam lobes per cylinder. However the valvetrain has the added benefit of roller rockers and continuously variable intake cam timing. The economy i-VTEC is more like the SOHC VTEC-E in that the intake cam has only two lobes, one very small and one larger, as well as no VTEC on the exhaust cam. The two types of motor are easily distinguishable by the factory rated power output: the performance motors make around 200 hp (150 kW) or more in stock form and the economy motors do not make much more than 160 hp (120 kW) from the factory.
In 2004, Honda introduced an i-VTEC V6 (an update of the J-series), but in this case, i-VTEC had nothing to do with cam phasing. Instead, i-VTEC referred to Honda's cylinder deactivation technology which closes the valves on one bank of (3) cylinders during light load and low speed (below 80 km/h) operation. The technology was originally introduced to the US on the Honda Odyssey minivan, and can now be found on the Honda Accord Hybrid, the 2006 Honda Pilot, and the 2008 Honda Accord.
An additional version of i-VTEC was introduced on the 2006 Honda Civic's R-series four cylinder SOHC engines. This implementation uses the so-called "economy cams" on one of the two intake valves of each cylinder. The "economy cams" are designed to delay the closure of the intake valve they act upon, and are activated at low rpms and under light loads. When the "economy cams" are activated, one of the two intake valves in each cylinder closes well after the piston has started moving upwards in the compression stroke. That way, a part of the mixture that has entered the combustion chamber is forced out again, into the intake manifold. That way, the engine "emulates" a lower displacement than its actual one (its operation is also similar to an Atkinson cycle engine, with uneven compression and combustion strokes), which reduces fuel consumption and increases its efficiency. During the operation with the "economy cams", the (by-wire) throttle butterfly is kept fully open, in order to reduce pumping losses. According to Honda, this measure alone can reduce pumping losses by 16%. In higher rpms and under heavier loads, the engine switches back into its "normal cams", and it operates like a regular 4 stroke Otto cycle engine. This implementation of i-VTEC was initially introduced in the R18A1 engine found under the bonnet of the 8th generation Civic, with a displacement of 1.8 L and an output of 140PS. Recently, another variant was released, the 2.0 L R20A2 with an output of 150PS, which powers the EUDM version of the all-new CRV
With the continued introduction of vastly different i-VTEC systems, one may assume that the term is now a catch-all for creative valve control technologies from Honda.
Old Jun 14, 2009 | 10:06 AM
GTS Jeff's Avatar
LOL at how every single post was brutally inaccurate until someone had the sense to post up the wikipedia page.
