Gas cap comes loose
Seems like my gas cap comes loose, first time i thought i didnt tighten it up after fill up. Since that time its happened twice, i make sure i tighten and hear a few clicks to be sure its tight, cap looks fine no cracks, rubber gasket is intact. Any one else have this problem ?
Try this it works also. When you put on the cap, grab it on the edge, not by the tab in the middle. You can tighten it much more that way and you may not have to replace the filler. Give it several tight clicks.
There was a tsb on it at one time.
fltsfshr
fltsfshr
Originally Posted by Slows2k,Jun 21 2009, 05:48 PM
The TSB is for a deformed fuel filler pipe. A new cap still won't seal on a deformed pipe correctly.
I had the problem, I never had the filler neck done, but that technique cured it on mine. I don't know if my filler neck is bad or not. I've replaced the cap once since then and it's almost 8 years now.
Let me know if that works
fltsfshr
fltsfshr
just tighten as you normally do (3 clicks) then grasp the edge and turn it some more..you will be surprise how much more it will turn and it will seal up..i do this all the time since mine comes lose every now and then and throws a check engine code..ever since i did the trick it never came lose and no check engine!!
On my O2, I got a new cap a few years ago. I put extra effort in screwing the darn thing down past the point of "casual" resistance and it works fine. I agree with people about pushing in and screwing so it doesn't "click" prematurely.
I don't understand the reluctance to actually fix the problem. It's very simple to DIY. And for most people who bought the car new, they could have even had it done under warranty. This is also a repair that Honda has covered under "goodwill" for many owners.
But people would rather keep going for years with having to squeeze the cap, getting the occasional CEL, replacing caps, etc.
A new filler neck and new cap, and your car works like it is supposed to work. Like you expect it to work. But OK, it's your car. Do what you want.
