Sponsored by:
Sponsored by: CARiD
DIY VIP lights
Old Aug 28, 2009 | 08:19 PM
AMBAICAR's Avatar
Talking DIY VIP lights
hey guys i was bored today and decided to go ahead and install the "vip handle lights" (this idea was not mine i took it from TRD Cellica) here is his thread https://www.s2ki.com/forums/index.ph...ic=725596&st=0
So i took a bunch of pictures and decided to do a diy here it is....
started off by pulling off ther weather strip directly above the top light (dome light)
placed in the wire for the lights i used speaker wire because im lazy and it was laying around
gotta look out for the metal supports on each side of the windshield in the corners there is a plastic piece that pops in to help hold on the weather stripping
the wires above the dome light block the weatherstrip from snapping back on so i had to trim a bit to get it around the metal to the light.
snip snip there is metal in there so be careful not to cut yourself
ran the wire down to the floor and popped off the plastic kick panel
(yes that is a sub in my passenger floor, no no one kicks it, no it doesnt take up more than 1'' of extra room compared to the stock floor)
so after that i removed the awesome piece of sponge insulation honda put in our car, along with the door pannel(3 screws), and the speaker to get in there a bit easier (the entire housing not just the speaker itself(4 screws))
i used the old wire hanger to fish through and pull the speaker wire through the factory holes it was fairly easy acyually
ps put ur windows up it helps alot
this is a shot of inside the door just follow those wires using the clothes hanger
right through to the other side
then i pulled off the plastic on the back side of the door to access the wiring with more ease.
look out for that crap they use to seal the door its nasty and sticks to everyhting
door handle before
door handle after
i fished the wires through the holes and used these clips to attach them incase one burns out it will be easier to replace
i used tiewraps to attach them out of the way of the windows
after that was all hooked up i wired it into the dome light the plastic piece pops off with a small flat head screwdriver
oh and i changed out interior lights to this red led looks good on the red/black leather(like the m3 lights)
to remove the whole lighting assembly you need a phillips screwdiver there is 2 screws on the sides of the lights
then here is the final result
hard to see because of the camera flash but they look good imo
what you guys think
Old Aug 28, 2009 | 08:24 PM
vollrathian's Avatar
havent seen this before
Old Aug 28, 2009 | 10:33 PM
dezymond's Avatar
If I were to mod a handle it would be the inside door handle. Passengers always have a hard time finding it.
Old Aug 29, 2009 | 07:10 AM
AMBAICAR's Avatar
that will be my next thing gotta pick up some red dim led's first and do something similar to what i did here with them ill add to the diy when i do it for you should be easy with the wiring already in my door.
Old Aug 29, 2009 | 12:11 PM
Moddiction's Avatar
Yeah I have been thinking of doing the inside door handles also. Would be nice to wire them up to go on when the e brake is engaged or something. Is there any way to wire them that way?
Old Aug 29, 2009 | 01:39 PM
AMBAICAR's Avatar
yea sure wire it to the switch that engages the e-brake light! nice idea!!
Old Aug 29, 2009 | 01:43 PM
Moddiction's Avatar
Yeah that would work out great. WOuld be annoying to have it always be on or have a switch to turn it on. If the e brake did it, it would seem oem like and be very useful.
Old Aug 29, 2009 | 01:49 PM
AMBAICAR's Avatar
something to check though would the e-breake switch still have power when the car is off? good way to kill the battery lol i learned from where i wired the vip lights that the lines above the switch always have power unless the entire light assembly is switched to the off position so i had to re-wire them directly ontop of the clips itself works now lol
Old Aug 29, 2009 | 01:54 PM
Moddiction's Avatar
Hmm not sure about that. I would think they would go off since the e brake light is not on constantly. Only goes on when the key is in the ignition. Hopefully someone with wiring experience can chime in.
Old Aug 29, 2009 | 02:01 PM
AMBAICAR's Avatar
yes but that is the same with te door lights only when it was closed the interior lights were off but the exterior lights stayed on idk i have a volt meter and can test it if no one knows off hand?
