ticking after valve adjustment
Old Sep 20, 2009 | 10:06 AM
fallen612's Avatar
Default ticking after valve adjustment
i got my valves adjusted on friday and now when the car is cold it makes rattling type noise when the car starts. almost like a babys rattle. mostly when i let out on the clutch to go in reverse or when i put it in first. but when its warm the noise goes away. anyone know what it could be? i also got the oil, transmission, and diff fluid changed. any ideas?
Old Sep 20, 2009 | 11:07 AM
siik_ap2's Avatar
the valves might be too loose
Old Sep 20, 2009 | 11:25 AM
03BlkS2k's Avatar
i had the same issue not too long ago. Found out that the valves weren't adjusted correctly. Get if checked out again.
Old Sep 20, 2009 | 04:52 PM
Kirpich's Avatar
Make sure the engine is cold. Like, hasn't been started in the last like 6 hours.
Old Sep 20, 2009 | 09:31 PM
rob-2's Avatar
Who did it? Did your car get driven into the bay to be worked on? Likely wasn't cool enough to do the work or the did it to the wrong spec.
Old Sep 21, 2009 | 11:47 AM
fallen612's Avatar
well after more looking im starting to think that they left something loose, but i havent found it. because i started the car cold and i heard the noise. so i poped the hood and the noise stoped. so maby somethings hitting the hood. but idk why it would stop when warm. anything close enoughf to the hood to make it rattle up against the hood??
Old Sep 21, 2009 | 07:12 PM
DocB04's Avatar
timing chain tensioner?
Old Sep 22, 2009 | 01:37 AM
FitzyS2k's Avatar
well its normal for the valves to tap when cold. once they warm up they will stop ticking. as for the tensioner the sound is of baseball cards in a bike spoke. same thing when cold noisy when warm quiet. also depends on amount of oil. if your low on oil then valves and tensioner can be loud. for example when it's time to do my oil change my tensioner will make the sound but once the oil gets up there it shuts up.
Old Sep 22, 2009 | 05:54 AM
fallen612's Avatar
no not low on oil. and the sound has seemed to not completly gone away but quiteted down some.the baseball car on a bike spoke is exactly the sound. should i still be worried?? thanks guys!!!
Old Sep 22, 2009 | 09:08 AM
K-Lo's Avatar
+1
