Steering Wheel problem
Old Oct 30, 2009 | 02:47 PM
ScoobyLai's Avatar
Default Steering Wheel problem
Problem: my steering wheel started jerking to the left when I turn a little at slow speeds or when I am fully stopped. Anyone else have this problem?
I did some research and found out the it can be multiple problems. And of all those problem I don't know how to check any of them to see if that is causing the steering wheel to jerk to the left.
Anyone know why or how to diagnose the problem?
Old Oct 30, 2009 | 02:52 PM
boostftw's Avatar
alignment? or something might be loose.
Old Oct 30, 2009 | 02:55 PM
ScoobyLai's Avatar
Well I read up on a few threads and most of them go get their cars realigned but the problem is still there.
They end up replacing the power steering rack....and I want to avoid that =)
Old Oct 30, 2009 | 03:26 PM
s2sik's Avatar
i would check all of the cheap stuff that takes a few moments first.
tire pressure, re-torque the wheel, check the shock.
then try to get the car jacked up, or on a lift.
axle, joint, steering rack, alignment.
Old Oct 30, 2009 | 03:33 PM
ScoobyLai's Avatar
I already took off the wheels and checked the shocks, and torqued the lugs to 95lb. I will check the axle as soon as I get a chance to this week.
How do I tell if the steering rack is bad?
Old Oct 30, 2009 | 03:53 PM
S2Kme's Avatar
Most likely your alignment. It could be your brakes too..
Old Oct 30, 2009 | 04:02 PM
ScoobyLai's Avatar
God dam it tommy! Lol well I do need to change out my brakes. It isn't time yet though but I don't remember when the previous owner changed them! want to help tommy (you already know I was going to ask) lol
Old Oct 30, 2009 | 04:19 PM
S2Kme's Avatar
Haha sure
Old Oct 30, 2009 | 04:32 PM
ScoobyLai's Avatar
Where you I get my brake pads? Go oem or aftermarket?
Old Oct 30, 2009 | 04:47 PM
S2Kme's Avatar
Oem ceramic
