Sponsored by:
Sponsored by: CARiD
ap1 with CR alignment?
Old Nov 11, 2009 | 09:51 AM
mr 280z's Avatar
Default ap1 with CR alignment?
im going to be going to Harris Hill Road in San Marcos, Texas this Saturday and i heard from a friend that i could get the CR alignment on my 2003 ap1. i have never heard about this on a ap1 and i wanted to know if anyone out there knows if that a good thing or a bad thing. i know that the suspension is stiffer but i want to know if it will benefit me at the track?
Old Nov 11, 2009 | 09:54 AM
S2KVITO's Avatar
I'm sure it will only help! The CR or euro spec alignment is designed with performace in mind not tire life for the US lol
Old Nov 11, 2009 | 09:59 AM
adrs2k's Avatar
Uk Alignment is two thumbs up! Although I run more front camber then what the UK spec.
Old Nov 11, 2009 | 01:27 PM
Hero's Avatar
don't know about the cr alignment, but i can highly recommend the uk alignment. car felt much better after getting this done.
tire wear will be faster though if this matters to you.
Old Nov 11, 2009 | 01:57 PM
Sebringer's Avatar
What are the UK alignment spec numbers?
Old Nov 11, 2009 | 02:00 PM
Captain_Liu's Avatar
which is more important in the uk alignment? Toe or Camber?
Old Nov 11, 2009 | 02:11 PM
ap1_tot's Avatar
Can someone be kind enough to enlighten us on the spec numbers for the CR, UK, and US alignment spec? for comparison purposes
Old Nov 11, 2009 | 02:52 PM
TheMuffinMan's Avatar
UK:
Front
Caster Left = 6.75°
Caster Right = 6.75°
Camber Left = -1°
Camber Right = -1°
Toe Left = 0°
Toe Right = 0°
Total Toe = 0°
Rear
Camber Left = -2°
Camber Right = -2°
Toe Left = +0.16°
Toe Right = +0.16°
Total Toe = +0.32°
Found the correct stock alignment specs and wanted to update for future searches:
Alignment specs:
All cars share the same front settings(00-03,04-08 and CR)
Camber...-0.50 -0.50
Caster....+6.00 +6.00
Total Toe....0.00
Rear....00-03
Camber...-1.50 -1.50
Total Toe...+0.47
Rear....04-08
Total Toe...+0.28
Rear....08 CR
Total Toe...+0.43
Old Nov 11, 2009 | 04:17 PM
street_ruler's Avatar
remember that the ap2 has different rear geometry than the ap1 so it has less bump steer
Old Nov 11, 2009 | 11:10 PM
mr 280z again's Avatar
well thanks for all the help im going to try to get the UK alignment tomorrow!
